gday just after some prices on turbo manifold, injectors, afm, ecu and intake plenum if all of this is needed if anyone can let me know some prices as loan will be approved within the next few days or so and im licenseless at the moment so got time and cash to work on it, if any one has anything they may be willing to part with let me know its not a certain thing just yet but if its all easily affordable and easy enough to put together i'm keen, cheers Paul :w00t:
https://www.sau.com.au/forums/topic/139103-thinking-about-going-r30-again/
So you're not interested in finding an R30 itself but rather the gear required to make it turbo?
About the turbo gear, 280zx-t stuff can do but the turbo is a shitty one so you'd have to get an R33 one or something. That stuff is sorta rare anyways.
N/A
You'd be better off putting an RB30 into it instead, that should make an MR30 pretty fast. (lightness factor).
Or you could do the L28 idea.
Turbo
Otherwise I'd just look into buying an RB20det second hand or sometihng and putting that into it.
As far as R30's are concerned in Adelaide, there aren't too many good ones for sale unfortunately.
Yea I would say go with a RB20DET(depending on budget) as you have heaps of engine importers in OZ compared to NZ so prices probably get more competitive for RB's and geting R30 turbo stuff over there is hard to find aparently and allthough you can find all the parts cheap as hell in NZ (like less than $400 for all thats needed to turn a non turbo into a turbo one) but freight is the killer there!
yeah i might have to go with the newzealand idea, i was just trying to do the easiest conversion as i dont have alot of knowhow about engine conversions so if i went with an rb20det i'd prob just buy an r31 i got roughly a grand or so to purchase the turbo gear so the freight really isnt a problem if i can get it all for about $400 coz i dont think it would be anymore then $600 for freight would it?? and yeah blue dynamite i've heard their turbo's are shitty and nasty so i prob would have upgraded anyway got a few grand to spend ontop of everything else aswell im just trying to find out what the better option would be, and would prefer the l24et idea as there really isnt many in adelaide i know there has been atleast 2 that i've known of and prob a few more, still debating about other vehicles just trying to figure out what i want and whats suitable but im keen on the turbo charged l24e as that was my plans before but a pole had to ruin that fun :laugh:
cheers Paul.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
