Hey guys need to upgrade my hairdryer....oh sorry my stock turbo on my rb25.....lol
Thinking of putting a gt3040r with a 0.63 rear housing so it can be more responsive. Searched it already but no luck.
Its a 600hp dual ball bearing turbo. Want to know how responsive its is and when full boost comes on?
Who ever has this info it would be most appreciated. Basically I want to increase my present 211.8rwkw to about to 260-270rwkw. HOWEVER, response and streetability is my first and foremost goal! Dont want a snail that has great peak power but poor low-mid range.
Any help would be great? I do not wish to hi flow coz its around the same for a new turbo these days.
https://www.sau.com.au/forums/topic/139265-garret-gt3040r-063-ar-conversion/
pfc injectors, pump, z32 etc etc.
all needed anyway
i have the HKS version of the 3040
291rwkw on 18psi with poncams
i have the 1.12 rear housing, so fairly laggy at full boost at 5000rpm
without cams you will still get boost about 4000 rpm-ish with that housing.. cant say for sure,
all needed anyway
If you think you need 'em for the 71, your gonna need 'em in spades for the 40.
You are right though!! :)
CAn you elaborate on this GT3071R
What size ex. A/R should i use?
What is it rated at?
Do i need a custom dump? How much?
How much is this turbo cost?
Is anyone running this turbo on a RB25? If yes please state mods and power made.
PS: I will put a pfc in with the upgrade and run about a bar of boost. I will in the future place some bigger injectors and z32 afm (or maybe pfc-jetro)
Thank You In advance!!!
I'd step down to the GT3076R (HKS GT3037 56 trim) or the GT3071 as mentioned. The GT3040R is a mismatch turbo and will be too laggy for your power targets.
I'd go one back again, 250-260rwkw is smack on the peak for the GCG Unit, and it gives insane response with great top end.
For the sake of having 250-260rwkw as opposed to 260-270rwkw (which can be attained by playing with dyno numbes if you need the sheet), i know what i'd choose for the RB25.
FOR F@#$%K SAKE! :O
Does anyone know the ANSWER to any of the above QUESTIONS???
Ahhhhhhhhhhhhh much better now.... :(:(:(
http://www.turbobygarrett.com/turbobygarre...1R_700382_3.htm
http://www.turbobygarrett.com/turbobygarre...R_700382_20.htm
try doing some research, you have been handed some info on a good choice.
price will depend on where you get it
custom dump pipe = YES - depends where you get it made
response - go for the 0.64
platter served
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
