  • Replies 41
i believe normal r34s run H1s but for some reason mine run H3s....wats the issue here and do u no which i should use?
dude doenst really matter what bulb your car has just change it with the one thats in it
if it runs a H3 bulb change it to a H3 kit
you might have H3's as you might have the halogen headlight assemblies? Early on in the R34 compliance stage, the entire headlight assembly was being changed. Now they just modify the Xenon assemblies.
either way, unless i see some pics... R34 owners at least will prob be quite disappointed with any HID changeover.
You really need the OEM parts... but again, waiting on pics.
man thats bs.....im so angry that they pulled em out far out. where can i get a set of the original xenons?
i hope i can count on u gohan to point me in the right direction with what kind of xenons i should get lol. i dont realli know why but i feel like H3s aint as good as the original h1s.....correct me if im wrong
you're wrong.
there is no different between the globe types, and what kind of light they produce.
if you had H3 in the left, and H1 in the right, you wouldnt notice a difference.
you're wrong.
can u explain why they converted my h1s into h3s?
s15 run projector headlights, yes?
projectors have a nice clean cut off, and are best suited to Xenon bulbs. Hence 99% of factory Xenon headlights are put in projectors.
R34's have reflector assemblies. Do your headlights have the word 'Xenon' embossed anywhere?
When was your car complianced?
original globes wouldn't even be H1's. They would be like D2R Xenon bulbs. Originals weren't even halogen's.
nismos15, could you take a pice of your headlights pointing at a garage door or wall?
do you have any pics of this kit in a car without projector headlights?
i have the word Xenon right under my buld....my car was done back in feb
posted some pics up of my headlights here
http://www.skylinesaustralia.com/forums/in...howtopic=140889
Edited by anDru
i have seen the 2 bulbs together there is not much difference just that the part that the H1 bulb sits on is different to H3 one to fit different headlights but the light looks the same
im not to sure with the r34 headlights but if you like a h3 i can get one for you no probs
hey which ones do you have your s15? as gohan said the projectors have a nice clean cutoff, does this still apply with the xenons?
ie the light pattern on the road looks the same as normal globes, besides being brighter/whiter/etc of course?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
