god this rain is pissing me off to no end and back!!!!!!!!!!!!!! BRING ON THE DRAG STRIP GOD DAM IT!!!!!!!! even bettter yet fix the staging area so water is not the problem! ok i got that out, im all good now. anyone out and about this weekend? ie driviing around ill join you.
got to love the f...cken retards in mackay who have no morals or give a shit about anyone else but themselves!!!!!!!!!!!!!i just parked in Mcdonalds in town this morning for about 5 mins even parked where there were no other cars where parked! come out and some f..ck wit has side swipped my car with a bull bar and pissed off!!!!!!!!!!! in the middle of mcdonalds car park and no one seen it!:spank: how god dam slack is that, my car mayy not be that nice paint wise but it sure as hell did not have a f..ck off dint on one side. learn from me dont leave your car anywhere! no notes nothing just sweet as my bull bar is fine so its all good.:rant:
Yet another reason I hate Mackay these days. Was a nice, sleepy town when I lived there (back in 94-96), but nowdays it's nothing more than an overgrown mining town, complete with the mining town mentality (ie I earn more money than you so I don't give a f*** about you).
Saw your car yesterday. Saw the dent but didn't know it was only done yesterday. Looks pretty average, fairly gay how it happened by the sounds of it
yea it was that morning! well and truely not impressed but cant do much about it now. guess its time for a respray. not sure if ill try if myself, paints stuffed now anyway so guess it wont hurt if i stuff it up :rolleyes:
