  • Replies 130
Martin would it be possible to have an overlap copy of the V8's 400+rwkw power torque curve and maybe your Soarer, a few r33's with different power levels and a couple of R32's thrown in their?
or
If I can have a copy of the above runs I will overlap them and make a post here ?!?!
Chris what mods?
Joel, HKS 2510 turbo @ 1 bar, FMIC, 3" exhaust, Bosch pump and re-mapped computer
Check out this dyno chart. This is from the weekend, a good comparison between Grepin and Freebaggins RB25 and my RB20. Just shows how much 1/2 litre makes a differance in the midrange
note - I have blurred out our rego numbers just in case there are theiving bastards browsing the forums for quick cars, but have marked which one is what
Just looking at the AF's Chris it looks like yours was running quite a bit leaner in the mid hence the power loss possibly?
I remember when mine was tuned similiar with similiar AF's it lost heaps in the mid range.
I found that running the mid a little richer (just under 12) made best power.
The PowerFC looks like it has a very good power curve and also AF' Ratios. hrmmm
Yeah, not to sure Joel. I just put it down to being 2L v 2.5L with variable inlet timing. If I compare the dyno chart from when it had the stock turbo on, the mid-range is virtually identical.
Going to use a electronic boost controller instead of the bleed valve to try and fill the mid-range in a bit.
Perhaps Martin could comment on this, as he tuned it and would have a greater understanding of this then I would?
I found with the EBC it actually came on to boost a little slower but was more controlled compared to the bleed.
I.e the Bleed felt quicker because it would spike up really quickly then boost would slowly drop off, the top end would flatten out where as with the ebc it still comes on hard but it is only hitting say 1 bar instead of 1.1 bar however the top end is better due to not loosing boost.
Might be different with the 2510 unless that drops boost up top also with a bleed?
Nah, doesn't drop off at the top end. I just want to see if it will get ti th 1bar quicker than it does currently
I'd like to get a EBC anyway, so I don't have to fiddle around under the bonnet if I want to run less boost. Wil be good to see what differance it makes on my car
OK, it's on, The "How Crap!" Challenge:
Gotta beat Chris32's RB20 power level.
Gotta beat MattR's RB25 powered power level (no it doesn't help mate).
Gotta beat Nightcrawlers 400m elapse time.
Gotta beat Martin's 1Jz power level.
....man-o-man. Give me some time & $$.
Freebaggin.
P.S. Also gotta keep grepin at bay!
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
