Ok. Thing is, its all still shimmed as it was before and nothing much has changed, just all new seals and bearings. Will it need to be re-shimmed? I was hoping just to check the teeth contact areas and if they were still ok to put it back together like that. Another thing, I didnt mark the pinion companion flange before removing it from the pinion shaft. Later i realised i should have, however it doesnt mention to do that in the manual and it normally would if at all necessary. Do you think it needs to be in a special way? Its not a master spline so there is many different ways it can be put it. What do i do?
Im getting a pair of Garrett 707160-5005 turbos this week coming! That will be exciting. This weekend i purchased a 2nd hand Trust oil cooler and filter relocator locally in Brisbane off 17SOK. Thanks to him for that. I need some help with the proper mounting of the core. Im not sure where exactly its meant to go behind the right hand duct. Ive got one friend getting me pics but if anyone else has one setup like that id appreciate a few more pics.
Deren
Turbos should have arrived by now?
I like reading the updates in this thread ;)
Hey mate!
Turbos arrived a couple of days ago. I ended up buying them off Chris Whittaker at MTQ Salibury here in Brisbane. I throughly recommend giving him a call if you need to purchase some new turbos as he was excellent to deal with and gave me by far the cheapest price! :(
I have added some new pics of the turbos including new vs old. Shows the difference quite well.
Before i fit the new turbos i will need to save up (now broke) for the stainless CES long front/dump pipes i have had my eye on :D As i will need to fit the first section to the back of the turbines before mounting them to the manifolds etc. Not much has been done to my GTR as i have been getting my daily (shitter) ready for the road. Its a 87 mitsubishi magna TN. Its hard to believe that these two cars were designed in the same era! I guess one being worth over 100 grand and the other being a run of the mill family car would have something to do with it. Since i took the GTR off the road (2+ years) i have had no car to drive so it will be nice to have a car to run around in!
Deren
Edited by Godzilla32
Deren
the 2 mounts on the left are using existing threads on the body
this mount goes to a hole behind the radiator overflow bottle u will need a screw, nut and washers.
mounted oil cooler.
cut hole for vent.
vent siliconed and rivited in place. though self tapping screws would be better as the rivets will stretch the plastic.
i made a duct out of template plastic. when finished make sure you cut at least 1-2cm back from the oil cooler. you
dont want it rubbing on it. i also used race tape to connect and hold either end. but the basic box is held together with self tappers.
underneath.
through front bar.
What can i say, thanks heaps for the help dude! Im worried mine wont fit there like that cuz of the twin bov's that are there? I'll go take a look in a minute.
Many thanks,
Deren
have you seen the oil cooler install by blk33 in the diy thread!
http://www.skylinesaustralia.com/forums/R3...lat-t79130.html
Looking good Deren.
Have you thought of getting stainless manifolds and dumps?
There are horror stories about poor quality stuff but I bought the dumps from Ebay and did a little work to get them as I wanted (some finishing with the die grinder to get the transitions smoothed nicely and dress some welds), and the manifolds I got from a forum member cheap as they needed to be skimmed flat. Almost 18 months making 320rwkw with no dramas at all. No cracks or leaks. Most problems are with one piece single manifolds warping but less chance with 2 piece for twins.
The big difference has been the extra power came easy. Same boost, 14psi, and an extra 70rwkw using highflows. The boost comes on much faster as well. Soon to retune to 18 or 20 psi to see how it will go.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
