Think im gunna stick with the stock manifolds but i definetly want some new dump pipes. I was in love with the CES pipes pictured I had thought they were only $700 in stainless. When i rang up they are actually $1800 and thats trade price! Unfortunately im going to have to draw a line there :P
I can't justify spending so much money on that part, as good as they might be. I can get new Tomei ones from Japan for $630 delivered. So thats another option. Ideally id like to pick up some quality dump pipes 2nd hand. Anyone got any they dont need?
I have got the covers all painted up and back home so ive added pictures of them. The timing covers are fitted but the cam and plug covers are just dummy fitted at this stage. Im going to get one more new cam cover gasket as last time i had the car apart i only replaced the one that was leaking. I also need to figure out what im going to use for the cam cover baffle material. Ive been told fuel cell foam, where do i get that from?
Deren
Call revolution racegear in Moorooka, or maybe Meridian motorsport in Melbourne. Don't ATI do fuel cells as well? Hunt around but I just leave the baffles alone and make sure the oil returns are good. I've just pickud up some nice Millenium Jade covers and an M-spec Nur cover garnish for the GTR, and the Racecar will get the crystal red covers and another M-spec Nur garnish.
The Tomeis are pure art. Ronin09 has them. My manifolds are a copy of the Tomeis and got them for 200 + 100 for the machining. My dumps are a basic short gate and 2.5inch pipe to make for easier maintenance as long ones are a pain. The dumps were about 200 and well put together but just no attention to detail on the gate merges but nothing a half hour of the die grinder didn't fix.
Deren
I thought you would have had all the hot parts ceramically coated? It made a huge difference to under bonnet temps on my old GT-R. From memory I had the turbine housings, exhaust manifolds, dumps, front pipes and exhaust manifold heat shields done. Gives them a nice black finish too.
Cheers
Brendan
I noticed you did that on your silvia. I was thinking about it but was told that its not as worthwhile coating the cast manifolds as they retain alot of the heat anyway. The extra expense is something i can do without too. Im getting very itchy to have it finished as im sure you can imagine!
Mate all i can say is that i'm in aaww at this project.
this is a truly inspiring rebuild. the attention to detail amazes me
keep up the excellent work and i hope you do show it when your done as i will definately
make the trip to see it in the flesh.
Cheers for sharing the build process
Hey Deren, seems things are coming along faster now, it would look good if u did paint the parts black to suit the engine stealth look. I bet your are itchy to have it finished, when do you suspect you'll have it finished (estimate)? P.S if you need a hand with anything, i only like 5 minz down the road. Goodluck, n keep it up! Hame
LOL at Brendan...Umm i was going to but i figured you cant see them at all once the heat shields and everything else is in place anyway. Ive used Tomei metal gaskets throughout and i have already torqued the exhaust manifolds so they will most likely stay as they are. I really cant be sure how long the rest of the build will take. All i can say is not too much longer i hope. Feel free to give me call and drop over whenever. Im on holidays until next week.
yeah no way will you see the manifolds if you use the standard heat sheilds, so don't bother.
I put the ces short dumps in and am very happy about their design and performance so far. not cheap retail price though
If i dont find a cheap 2nd hand pair of dumps i will most likely get the Tomei ones i mentioned..
Hey there deren, was nice to catch up, how is she coming along now? This project looks great on here but even better in the flesh can't wait to see her back on the road! Get the Tomei ones, it won't let you down too much, however i sure we''ll all keep our eyes out for CES pipes for you.
Last night i fitted the oil and water feed lines onto the new turbos. They have been cleaned out throughly, especially the oil feed. It took some gentle persuasion to get it all to bolt up. I was a little worried at first that i wouldnt be able to get it to fit but its all good :)
Yesterday at work i tensioned the pinion nut up on the front diff with the new bearings etc fitted. I havent had much experience in this area yet. The pinion is a little stiff to turn now and now that the crown wheel is installed there is a tiny bit of a knock when you rock the crown wheel back and forth...Seems to be just the gap between the crown wheel teeth and the pinion teeth. Is this normal? I have reused the original shims as i havent changed anything besides the bearings and seals. Im yet to run some bearing blue to check for correct meshing...
Does anyone know for sure if thats normal?
Deren
Deren,
Wow. I have just spent about an hour reading this whole thread. You are living my dream. lol. Your attention to detail and commitment to your cause is commendable. Good luck and I hope it all works out for you?
Looking forward to seeing more pics!
indeed they do - they are turbo outlet to cat. but the shape/length of the pipes makes it hard to get the motor in and out. if you are only doing it once you will be OK i guess, but if you need to do the motor quickly or a few times it will really start to annoy you
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
