Think im gunna stick with the stock manifolds but i definetly want some new dump pipes. I was in love with the CES pipes pictured I had thought they were only $700 in stainless. When i rang up they are actually $1800 and thats trade price! Unfortunately im going to have to draw a line there :P
I can't justify spending so much money on that part, as good as they might be. I can get new Tomei ones from Japan for $630 delivered. So thats another option. Ideally id like to pick up some quality dump pipes 2nd hand. Anyone got any they dont need?
I have got the covers all painted up and back home so ive added pictures of them. The timing covers are fitted but the cam and plug covers are just dummy fitted at this stage. Im going to get one more new cam cover gasket as last time i had the car apart i only replaced the one that was leaking. I also need to figure out what im going to use for the cam cover baffle material. Ive been told fuel cell foam, where do i get that from?
Deren
Call revolution racegear in Moorooka, or maybe Meridian motorsport in Melbourne. Don't ATI do fuel cells as well? Hunt around but I just leave the baffles alone and make sure the oil returns are good. I've just pickud up some nice Millenium Jade covers and an M-spec Nur cover garnish for the GTR, and the Racecar will get the crystal red covers and another M-spec Nur garnish.
The Tomeis are pure art. Ronin09 has them. My manifolds are a copy of the Tomeis and got them for 200 + 100 for the machining. My dumps are a basic short gate and 2.5inch pipe to make for easier maintenance as long ones are a pain. The dumps were about 200 and well put together but just no attention to detail on the gate merges but nothing a half hour of the die grinder didn't fix.
Deren
I thought you would have had all the hot parts ceramically coated? It made a huge difference to under bonnet temps on my old GT-R. From memory I had the turbine housings, exhaust manifolds, dumps, front pipes and exhaust manifold heat shields done. Gives them a nice black finish too.
Cheers
Brendan
I noticed you did that on your silvia. I was thinking about it but was told that its not as worthwhile coating the cast manifolds as they retain alot of the heat anyway. The extra expense is something i can do without too. Im getting very itchy to have it finished as im sure you can imagine!
Mate all i can say is that i'm in aaww at this project.
this is a truly inspiring rebuild. the attention to detail amazes me
keep up the excellent work and i hope you do show it when your done as i will definately
make the trip to see it in the flesh.
Cheers for sharing the build process
Hey Deren, seems things are coming along faster now, it would look good if u did paint the parts black to suit the engine stealth look. I bet your are itchy to have it finished, when do you suspect you'll have it finished (estimate)? P.S if you need a hand with anything, i only like 5 minz down the road. Goodluck, n keep it up! Hame
LOL at Brendan...Umm i was going to but i figured you cant see them at all once the heat shields and everything else is in place anyway. Ive used Tomei metal gaskets throughout and i have already torqued the exhaust manifolds so they will most likely stay as they are. I really cant be sure how long the rest of the build will take. All i can say is not too much longer i hope. Feel free to give me call and drop over whenever. Im on holidays until next week.
yeah no way will you see the manifolds if you use the standard heat sheilds, so don't bother.
I put the ces short dumps in and am very happy about their design and performance so far. not cheap retail price though
If i dont find a cheap 2nd hand pair of dumps i will most likely get the Tomei ones i mentioned..
Hey there deren, was nice to catch up, how is she coming along now? This project looks great on here but even better in the flesh can't wait to see her back on the road! Get the Tomei ones, it won't let you down too much, however i sure we''ll all keep our eyes out for CES pipes for you.
Last night i fitted the oil and water feed lines onto the new turbos. They have been cleaned out throughly, especially the oil feed. It took some gentle persuasion to get it all to bolt up. I was a little worried at first that i wouldnt be able to get it to fit but its all good :)
Yesterday at work i tensioned the pinion nut up on the front diff with the new bearings etc fitted. I havent had much experience in this area yet. The pinion is a little stiff to turn now and now that the crown wheel is installed there is a tiny bit of a knock when you rock the crown wheel back and forth...Seems to be just the gap between the crown wheel teeth and the pinion teeth. Is this normal? I have reused the original shims as i havent changed anything besides the bearings and seals. Im yet to run some bearing blue to check for correct meshing...
Does anyone know for sure if thats normal?
Deren
Deren,
Wow. I have just spent about an hour reading this whole thread. You are living my dream. lol. Your attention to detail and commitment to your cause is commendable. Good luck and I hope it all works out for you?
Looking forward to seeing more pics!
indeed they do - they are turbo outlet to cat. but the shape/length of the pipes makes it hard to get the motor in and out. if you are only doing it once you will be OK i guess, but if you need to do the motor quickly or a few times it will really start to annoy you
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
