nissan skyline 2 door hr31 for sale
rb25 with rb25 gear box, front mount, hsd coil overs all round woth s13 front control arms and s15 tie rods and ends the new just jap style, haltech e11v2 computer, sparco bucket seat red in colour stripped interior, full 3 inch straight through exhuast, r200 locker, 8 inc wide valk racing rims on the front with 90% tread and stock sr wheels on the rear, tuned by jem and when car is sold it will get a new tune for the new owner the car has around 200 at the wheels, heavy duty clutch, just put a r34 turbo on the motor, new 550hp walbro pump
car is gun metal grey with black 2 tone
car is located in sydeny nsw
i have just spent 13g in the past 4 months the car has all the interior aka 2 front seats
$11000 ono [email protected] or call me on 0404350919
thanks brendon
this car has too be sold i need a minni truck for my bikes
Edited by slida
https://www.sau.com.au/forums/topic/140092-for-sale/
come on ppl this car has too go i have put a deposit on a ute and this car needs too go.. car got a new tune yesterday i havent found out wat it made with the big pump in it now but when i rang too see how it was going they were really impressed with it so fair.... i am really neg on price now it has too go
https://www.sau.com.au/forums/topic/140092-for-sale/#findComment-2669219
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
