heh u noticed that too eh?
A mates 32 has all 4 that lights up and only 2 do on mine. I agrree - A little info from some1 would be great.
btw 32godzilla is that your car on your avatar? Its hot! What sorta front skirt extension/front bar have u got on it??
My understanding is that correctly complied cars (ie no shortcuts) only light up two outside tail lights with parkers, and when you brake all four light up.
My car lights up all four with parkers/headlights, and when i brake they simply glow brighter. Ok so my car wasnt complied properly... so what.
... and in case a complier chooses to attack me for providing misinformation about the industry, this is what has been said about my car.
Shortcuts isnt necessarily the reason. I spoke to my compliancer about this very issue. He said the paperwork he recieves from canberra sometimes has it listed, sometimes it doesnt. A compliancer will only do what is listed as a requirement.
Apparently the ADR papers vary not only in years of production but in MONTHS of production too. Its very strange.
Red17
My b/f got told when he got his GTR that in compliance two of the lights are disconnected/cut as when you look an an Aussie delivered 32 GTR, their indicators and reverse lights are different to the imported version, i.e An import's indicators are where an Aussie delivered's reverse lights are, apparently.
It easy just to re-solder the wires back together, then you'll have all 4 light up.
Thanks for the info people, I'll have a look for any "cut" wires and post another reply as soon as I find anything. Four lights look better lit up than two i reckon - that's all. (like the 33's)
deorbit, not sure what front lip I've got as it came with the car, and to be honest never realised until about 2 weeks ago when I checked out another 32 GTR!
I finally had a look the other day and yes there was a green wire in each light cut, just crimped them back together and 4 lights.
Prank, that sounds about right but why then do R31 Skylines have the same set up i.e. 5 brake lights and parker lights??
I have heard that they disconnect the outside two tail lights because there is an ADR that says something about the indicators are not allowed to be in board of any tail lights....hence the disconnection.... Also explains why Nissan rearranged the light configuration on the Aus-spec GTR's.
But as you have found out, piece of piss to reconnect :P:P
The ADR rules say that you need to disable the park lights on an R32 GTR, but as for R32 GTSt, there's no such rule as yeah, there is a center brake light. If you were to remove this, I'm told you can dicked by the cops for having all 4 afterburners active. But I've never heard of this ever happening so muh.
Lol I've got a spoiler brake light AND my SKYLINE lights up too (factory option)... now if I can get a replacement bulb and be bothered putting it in then yeah I'd be driving with 6 brake lights lol.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
