i did clean it with a dremel slightly, is ur's a s2 motor?(maybe i got a s2 motor, i duno) can any1 else answer this?
yes car is a series 2. and ignitors built in coilpack. but i didnt think that would have mattered?
  • Replies 58
ya mine are like that to.. all shiny and clean looking... i was disapointed cause i was hoping theyd have heaps of crap on em :D
mines a s2 also.
just had a look at mine a while ago and it looks metal as well. unless the actual 'metal' is junk and once cleaned it comes up with the copper look.
going to my friends house saturday morning ... doing 2 s1 33's at the same time... will let u know how it goes... no pics sorry :S but will tell ya if its a fix his misses day and night mine only misses in the cold night
got pics.
The coil that was arcing out the most did have the most crap in it.. But it isn't that bad. :S
I'll now clean them up and see how it goes.
You can see the darker off looking colour. The camera lightens it up quite a bit more but the color is quite dark.
Cleaned up the small amount of crap inside the coil..
And noticed a cracks on all the coils, some noticeably cracked, others didn't look cracked but under the camera they obviously were starting to do so. Quite difficult to see but the camera in macro mode shows the crack very nicely.
And fingers crossed.. the silicon does something.. Either way I know I'm up for a set of coils and cleaning the inside in my case isn't going to jack. :devil:
Mine have been on the car for 220,000km's + what ever it was wound back. They were very clean in side the coils apart from one that only had a bit of gunk as posted above in a previous post.
They all had cracks in the same place. I was unable to find any others but its quite possible there is one under the bracket that holds them to the larger bracket.
good work mate.
keep us posted on how it goes.
the silicon might melt, so keep an eye on it somehow.
if it does melt, you might get away with pushing some araldyte into the crack as much as you can.
A quick google - silicon has a melting point of ~1410degree's c.
http://www.google.com.au/search?hs=nAi&amp...earch&meta=
Hrmmm sounds a tad high as I've melted silicon in the past with a soldering iron, maybe 'pure' silicon? :devil:
As I can only really see the first 3 coils, number 2 with the big crack in it still sparks and can be seen at night :laugh:.
Number 1 and 3 that were only starting to crack don't light up anymore. I might pull them out again after a little driving and see if I can see arc marks and how the silicon is holding up.
just pulled mine out today.... originally they looked like the first pic posted on page 1.... grey crappy looking etc... could not see color... NOW they are nice and coppery shiny woooot lol had a few cracks used the industrial grade stuff ... 203C continuasly see how it goes when it dries and i put them back in!
All though I can still see the coils arcing out once warm I am no longer getting the pop/miss fire.
So it has worked, I'm not running much boost at the moment (12psi) so with more boost it may very well fall on its face again.
A new set of coils are going in none the less.
A mate of mine runs 16psi through a highflow and thats popping badly where a massive power loss is felt. I'll silicon up his in a week or so and let you all know how it goes. :)
Also.. The silicon is holding up perfectly fine. No peeling, melting etc.
I did make sure I cleaned the coils well prior (prepsol)
Guest Rotary20B
A mate of mine runs 16psi through a highflow and thats popping badly where a massive power loss is felt. I'll silicon up his in a week or so and let you all know how it goes. :(
What sort of silicon are you guys using? How long does it take to dry etc?
Mine misfires badly around 4k up running around 12psi.
I pulled the coils out on the weekend, couldn't see any cracks, mines looked like the pics on page 1 to begin with, cleaned up well.
Put them back in, not much difference, I did notice it was a little better, still can't give it full throttle though.
With the silicon and cleaning the coils, what are you gapping the plugs, .8 or 1.1?
Plugs must be gapped at 0.8mm
The cracks are quite hard to see. I missed them at first. The ones that I thought were not cracked under the camera showed as they were indeed.
I think they must also crack some where else as I siliconed up the crack that I could see yet i can see it arcing on the opposite side.
Either way its fixed the pop for me for the mean while.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
