after reading a mighty good thread on small singles or even big singles on gtrs i decided to stay low mount twin! it was going to cost well over my budget anyway?
i am only looking for around 300-320awkw this is what i think ill need,if there is anything missing or i have something there that isnt needed would be great if yous could let me no?
pfc+hand controller
550cc injectors
z32 afm+plugs
front pipes(just jap or should i get hks)
cam 260 duration 9.1 lift
cam gears
new cooler core
fuel reg
oil cooler and relocater
now with turbos this is where i would have to be careful so not to blow the budget
so ive seen some r32 gtr n1 spec turbos for about $1200 what are these thinngs like if someone could shed some light
gt-ss bit pricy but would the best option
gt2860r with either -5-7 not sure what these are like b ut sound good for $2700
so any help would be greatfully appreciated
regards kane
https://www.sau.com.au/forums/topic/140315-new-setup/
  • Replies 281
pfc+hand controller
550cc injectors
z32 afm+plugs
cam gears
new cooler core
fuel reg
regards kane
GT-SS's pricey?
The Aussie dollar buys over 90 Yen at the moment so its an awesome time to buy. The GT-SS complete kit brand new should cost you a touch over $3k delivered.
They will be more responsive than the 2860's and will easily accomplish the power you want.
My GTR is producing 320awkw on a safe tune with them at the moment.
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2614346
517's arent as good as the GT-SS mate. Dont come close.
GT-SS comes in the kit remember, so everything you need.
You'll need to change the dumps though, the stock ones will hurt.
Stock manifolds are quite ok however
Dont get R32 N1's, they are shocking. There is a very good reason they are so cheap :P
Old design & shocking/poor response.
Its worth the extra $1500 for decent turbos.
everything else you have seems about right, except you want Nismo AFM's, not Z32's.
Otherwise you have to change intake piping and thats a mission if your on budget
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2614498
thanks alot mate, wasnt to sure of the r32 gtr n1 turbos.
about those air flow metres where could i find those?will i have to change plugs with them?
hks dumps be fine from nengun
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2614655
Boost controller, replace coils, while you are doing large upgrades...........
...replace oil pump , water pump and timing belt....get the bearings and bolts changed at the same time though.
Then after it has cost you $5000+ :) to install your $7000 :P dollars of parts you will need to upgrade
or pay some attention to the brakes and suspension......and after $3000 :O of this....
.....you will then need some rims and sticky rubber so you can get a 1/4 mile result...this would cost about
$4000. :O And you haven't finished yet.
Believe me ....cause these are the figures you are facing.....
If you are worried about $3000 wait until you finish your upgrades. :)
As far as the -5(2530) turbo's.....they are the best choice for 320AWKW's and you have to have the Poncams to get this figure.
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618590
The 2530 is NOT the best choice for 320rwkw
They are the BAD choice
We have already established that earlier on
And i bet i can get over 300rwkw with the stock cams, thats my aim with the GT-SS, just a cam gear :)
He has stated he wants 320AWKW's not rear wheel.
I have the 2530's and am at 260AWKW's...I need Poncams to get me to 320AWKWS.
Or have I mis-understood his intentions?
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618633
Can i be your mechanic :) You seem to enjoy overkill...nothing really wrong with what you are suggesting i suppose...but id like to think that a GTR owner that is about to do these sorts of mods has a properly serviced car....so no need for new water/oil pumps, timign belts, coils etc etc
What boost have you up your thing for only 260kws with 2530s ?
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618686
If you read the..........engine failure thread.... you will be suprised on how many people get into trouble
because they believed the odometer reading in there car.... :)
When you are searching for more horses, as stated many times you need the mods and then you need the supporting mods. If their is any doubt in your mind ,that, their could be some issues with the current oil pump or water pump, you need to fix this first.
The last thing I would hate is to recommend something when I do not know the state of his vehicle.
The last thing he needs is to spend money...and then blow his motor...because of a timing belt , bearing or bolt
due to poor maintence.
Roy...my boost is at 1.3 bar and I have a 7500RPM cut out.This gives me 330RWKWS..
Poncams I am hoping will get me to 300AWKWS :P
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618726
AWKW and RWKW is the same thing... so im not sure how your confusing the intentions here.
I dont think you realise there is absolutely no difference between the two.
Dirtgarage tested AW & AW it, 1kw difference which is nothing but dyno variance at its best.
If you have 260 @ the tyres and your being told you need poncams for 320, then your mech IMO does not know what they are doing, time to have a chat with them or find another.
A stock turbo's GTR will pretty much make 260 @ the tyres. Let alone putting bigger turbos on it.
As stated, 2530's will net you around 370rwkw. They are not the turbo for 320rwkw/awkw or whatever other 4 letters you can think of
This information is all over the forum in a dozen different threads.
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618739
i had in mind the oil pump,but as for timing belt water pump(n1) bearings bolts all done about 5k ago.... suspension ill leave for now,breaks aint to bad...
also i had poncams and gears as my choice already 260 9.1 lift so on... i think the gtss will do fine for what i want. and also the i alaways thiught awkw was the a rwkw 2..thanks for info guys keep it coming
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618803
Poncams I am hoping will get me to 300AWKWS :)
Again point taken...but what your suggesting isnt a common denominator. You dont have to do what you have posted for it to be reliable, provided you know the history of the car, which i would say most owners know, or mechanics can inspect. But agree, if you dont know the condition of the car then hold off on the mods until you have owned it for a while
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618804
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
