  • Replies 281
yeh im stinging to see what she makes?
does anyone no what boost the 2860r make on the actuator setting they come with?as im not running any sort of controller/
I've heard the wastegate spring is adjustable, and that the factory setting is 1 bar.
That's second hand info, so treat it as such.
Dan
It depends a bit on the exhaust system but if you have a free flowing system with high flow(or no cat)cat you should see ~0.9 to 1 bar boost off the actuators, and a reduced boost level if the exhaust is restrictive at all.
pete
i have justjap dumps whick look to be nice and free flowing,2.5inch in to 3inch stainless dumps,stock gtr cat and 31/4inch titanium cat back. i want to run about 22psi so how should i adjjust them? or should i run a bleed valve
the std cat is going to have a dramatic effect on the system and why do you think you need 22 psi the extra boost doesn't always gain big results the -5 i have found on the rb26 seem to hit a sweet spot around 18 psi and the after 20psi the gains for boost increase fade, so for the extra stress your putting on the engine and turbos it's offen not worth it. 18psi quiet offen can see a healthly well sorted rb26 pass 510rwhp+ but if your looking for figures inexcess of 530-540 your should most likely be looking for a different combo and you'll have to sacifice responce to do so.
As for controlling 22psi you WILL have to buy a electronic controller to get the consistent control required or you will suffer the swings in boost pressure from different temperature conditions which at that level could be dangerous at 18psi a swing of 1 or 2psi isn't to scary but 22 plus 2 or 3psi and your getting very close the design limit of the centre cariridge of 2 bar.
pete
Edited by pnblight
pete
thats the info i was after,so 18psi should see the 320awkw im after or maybe bit less wouldnt matter?
profec b sounds to be ok so i might look into them.. thanks again all
  • 1 month later...
I'll 2nd Seans call on a MetalCat. I bought my GTR with a straight pipe in place of the cat & when I swapped it out for a 4" MetalCat flanged back to 3" to match the exh there was basically no noticeable difference in performance whatsoever.
BTW didn't you lose your licence awhile back?? Might explain why you're in no real rush to throw everything at the car ;)
BTW didn't you lose your licence awhile back?? Might explain why you're in no real rush to throw everything at the car :P
He'll be on the road again, before you know it.
Not when all the parts are ready to put on. :happy: get moving!
yyeh yeh im just getting motivated...4months 1 week till im legally aloud to drive again so ill prob get more motivated then...
still its a pain not even being able to start it and hear the noise of my rb26....grrrrr
Man, i there with you. Mines been off the road for.. *gulp* 12 months. Have a mass of power steering lines to re-route, 12v feeds to run through the cabin, engine oil cooler to finish lining up... all waiting till i can get my tahbin and m.fold - i LONG for the sound of the RB again
It can often be hard to get under the gurl in the ever colder nations capital, to be covered in PS fluid.
At the moment im on a raising rate dose of HiOctane / JDM vids, plus 80's Rally docos' and rides in mates fast rides
Almost there, have faith man
M
Edited by GeeTR
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
