guys, don't jump the gun, i'm pretty sure there might be a clash, cup day weekend on the sunday there is a passenger day at sandown (presidents day, or something like that) which is twice as close and...well...you get to go in porka's :D
Edited by R32gts-t
jesus might be seen at sandown, hanging with a tall dark and extra handsome man, I think his name is all mighty Greg!
AAHAHAHA,
come to sandown you softess cockess, Deano might even get you a seat in a new toy :yucky:...can't promise anything though, as i'm calling shotgunssss
hahaha now you've really got me confused!
Be part of the tall, dark and handsome club, AND get to hang with the almighty Greg... and go in porsche goodness... OR see extra porsche goodness blasting around a super sexy hill climb event.
I may be persuaded with rides in super mega ultra turbo's... or is it a new new toy... JARGH
it's not really my place to say... Deano's old man was tired of teh nissan, and didn't want to track the 996..... i'll leave it up to your imagination, it's older, but still newish,
has a german acsent and it breathes for itself (NA). very cool too. :whistling:
there is already a few people with their hands up for moustache rides, so i wouldn't base your decision on which event to go to around a whim of a ride. i'm fairly certain deano has permission to stretch the s14's legs too. so the eye candy at sandown this sunday will be fantasmiktoricle.
If you decide to rock to my buller be sure to say hi to Jamie, he'll be blasting around up there with his old man.
Edited by R32gts-t
I take it there is an RS nomenclature associated with said car... or perhaps GT... hmmmmm I wanna see it!!
So is the S14 getting sold??
Ahhh, I don't know what to do, too much good car stuff on at the moment!!
If I do Mt Buller I'll say hey to Jamie, which porsche will they be in?
S14 definately stays, i drilled dean and his old man that they have come too far to hand ball it off, dean knew this all along too, it's still an awesome machine.
I have no idea about jamie,
they have a fair few to choose from, you never know which one they'll take.
Last presidents day i was lucky enough to hitch a ride around sandown in his dad's 993 turbo it's got approx 400rwkw 240kph back straight, harnesses have never felt better to hang from under braking :D.
Edit: I now know what nomenclature means hahaha, mr vocab.
for those that care: http://dictionary.reference.com/browse/nomenclature
Edited by R32gts-t
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
