Last time I looked they did...did a really good job of binding up on the dipper at Bathurst and spearing them off in to the kitty litter
Sports cars are a nice handling over all package.....the viper is a large powerful engine attached to a chassis built manily around 2 bits of railway track
LOL RAILS...
did u see the lotus come over the peak too fast hit the strip and bounced off a wall and into the service road..??? 900kg 1.8L toyota engine ftw...the donut king cup thingo..
was a good race.. EVOS wer crazy.. and did u see the FD3S behind everything..?
FD3S are a sports car.. good overall package.. but they are kinda gutless.. like the RX8 bahaha... waste of engineering.
hi all,
im new to sau ive come over from the exa club as i had an exa now i have a skyline and am in desperate need of your help i have a r33 gtst series II 4 door auto yes i know its a friggin auto it sucks yadda yadda yadda anyways i got a bigger front mount a bigger turbo power fc and viper alarm system also window tint and pearled paint anyways i had a loose wastegate actuator and when i fixed it (as boost was coming on at like 5500rpm) it now gets full boost at 2000rpm the car is pinging like a bitch i cant afford to take it to a decent dyno and im looking for a stock ecu and decent boost controller to swap for it. i managed to get the car pinging not so much by self tuning as best i could but just want the stock computer and boost tap if anyone can help me out send me an email at [email protected] please cos im desperate to get my skyline working good btw i live in beenleigh but work at capalaba at bryan byrt ford >_< lol thanks guys.
The power fc needs to be modified to work on an auto car, you CANT run a power fc out of the box on an auto car. Yes it will work, no it won’t work right.
SydneyKid on these forums made a post in the tech sections explaining what needs to be changed to work, he runs one on his auto Stagea
hmm SK is smart.. hes a good bloke..
makes me wonder what he looks like..?? anyone got a picture of him im keen to see if he looks asian with white gray hair and long kung fu mostach
Power fc's dont run on auto cars...
This is true. I think his biggest problem will be with the Power FC.
My advice consist's of the following, seeing i owned a 4 door r33 auto at one stage.
1) Post in the WTB section of the SAU forums and let people know you need an R33 Series 2, Auto ECU.
2) Disconnect car battery and remove the Power FC ECU and hand controller (if it has one) and replace with your second hand r33 S2 Auto ECU.
3) If you already have a boost controller, i'd piss it off pretty quick and reconnect your boost lines into the stock boost solenoid to ensure either of the two items above arent causing the problem.
4) If the problem is still there and your running a stock ecu and boost solenoid, i would then locate another wastegate actuator and replace your current one. If your actuator is allowing your gate to open quickly, your turbo will spool around 8-12psi in an instant shot and give you a massive amount of boost spike.
However, you mentioned you had issues at 5,500rpm (Wastegate not opening soon enough), and now it spools to early (Power FC problem, Wastegate opening to early...Way to early...)
I'd seriously give the above a fair go.
Good luck. :rofl:
Chris
Edited by SunnyCoast
Welcome to the forum.
You said that you had a loose wastegate? how did you fix it? I'd be definitly pulling the power fc out like the others said as they obvously not suited for autos .If you cant pull the fc out for now take a few degrees out of the timing ( get one of your mechanics to do it, thats if you are desperate so it doesnt ping might, make the car not responsive). What fuel have you been putting into it ?Hopefully nothing under bp ultimate.I wouldnt be running any boost controller until your problem is fixed so get that wastgate sorted out or your chances of engine damage will be up there.
Good luck
Good luck
Ditto :D
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
