Last time I looked they did...did a really good job of binding up on the dipper at Bathurst and spearing them off in to the kitty litter
Sports cars are a nice handling over all package.....the viper is a large powerful engine attached to a chassis built manily around 2 bits of railway track
LOL RAILS...
did u see the lotus come over the peak too fast hit the strip and bounced off a wall and into the service road..??? 900kg 1.8L toyota engine ftw...the donut king cup thingo..
was a good race.. EVOS wer crazy.. and did u see the FD3S behind everything..?
FD3S are a sports car.. good overall package.. but they are kinda gutless.. like the RX8 bahaha... waste of engineering.
hi all,
im new to sau ive come over from the exa club as i had an exa now i have a skyline and am in desperate need of your help i have a r33 gtst series II 4 door auto yes i know its a friggin auto it sucks yadda yadda yadda anyways i got a bigger front mount a bigger turbo power fc and viper alarm system also window tint and pearled paint anyways i had a loose wastegate actuator and when i fixed it (as boost was coming on at like 5500rpm) it now gets full boost at 2000rpm the car is pinging like a bitch i cant afford to take it to a decent dyno and im looking for a stock ecu and decent boost controller to swap for it. i managed to get the car pinging not so much by self tuning as best i could but just want the stock computer and boost tap if anyone can help me out send me an email at [email protected] please cos im desperate to get my skyline working good btw i live in beenleigh but work at capalaba at bryan byrt ford >_< lol thanks guys.
The power fc needs to be modified to work on an auto car, you CANT run a power fc out of the box on an auto car. Yes it will work, no it won’t work right.
SydneyKid on these forums made a post in the tech sections explaining what needs to be changed to work, he runs one on his auto Stagea
hmm SK is smart.. hes a good bloke..
makes me wonder what he looks like..?? anyone got a picture of him im keen to see if he looks asian with white gray hair and long kung fu mostach
Power fc's dont run on auto cars...
This is true. I think his biggest problem will be with the Power FC.
My advice consist's of the following, seeing i owned a 4 door r33 auto at one stage.
1) Post in the WTB section of the SAU forums and let people know you need an R33 Series 2, Auto ECU.
2) Disconnect car battery and remove the Power FC ECU and hand controller (if it has one) and replace with your second hand r33 S2 Auto ECU.
3) If you already have a boost controller, i'd piss it off pretty quick and reconnect your boost lines into the stock boost solenoid to ensure either of the two items above arent causing the problem.
4) If the problem is still there and your running a stock ecu and boost solenoid, i would then locate another wastegate actuator and replace your current one. If your actuator is allowing your gate to open quickly, your turbo will spool around 8-12psi in an instant shot and give you a massive amount of boost spike.
However, you mentioned you had issues at 5,500rpm (Wastegate not opening soon enough), and now it spools to early (Power FC problem, Wastegate opening to early...Way to early...)
I'd seriously give the above a fair go.
Good luck. :rofl:
Chris
Edited by SunnyCoast
Welcome to the forum.
You said that you had a loose wastegate? how did you fix it? I'd be definitly pulling the power fc out like the others said as they obvously not suited for autos .If you cant pull the fc out for now take a few degrees out of the timing ( get one of your mechanics to do it, thats if you are desperate so it doesnt ping might, make the car not responsive). What fuel have you been putting into it ?Hopefully nothing under bp ultimate.I wouldnt be running any boost controller until your problem is fixed so get that wastgate sorted out or your chances of engine damage will be up there.
Good luck
Good luck
Ditto :D
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
