Nah, bought better pads...still same problem.
Rotors are glazed and i am not maching brand new $1000 rotors....Feats the whole point of being brand new and slotted. Seems the new pads are wearing the glaze away slowly...
yeh keep at it. bed the brakes in properly..
or a can of de-squeak will work
Hey, guys just thought i would ask you guys what you thought my car has the popping sound at around the 5000 rev mark but keeps acelerating through till 7000 rev, it is really anoying and need to get it fixed.
So far i have found out it is likely to be the coil packs and there are cheap ways to fix them or i can just get them replaced, is this my problem?
I will be getting the sparkplug done at the same time.
get the plugs done by themselves first.. then come back and tell us the results. do a progressive assessment. u wont need new coils unless their fkd
keep it simple man.
* u dont want to spend $500+ on coils, when stockies can cope with 300rwkw, and may no need changing.
http://www.skylinesaustralia.com/forums/Sp...ls-t147724.html
"A few of the blokes on there with higher powered 500awkw+ GTR's have had ignition break down issues with the splitfires. They drop the genuine coils back in and the break down disappears."
Edited by r33cruiser
yep well could be tips of plugs r gone. but my guess is the coilpacks are breaking down.
Rabbit - I had this problem on my R33. To fix the problem, i'd do the following.
1) If your running anything above your stock 7PSI boost, turn it back down and the problem usually goes away - Higher boost causes this problem.
2) If your boost is stock, remove your spark plugs and replace them with some ngk iridium plugs (around $19 each - but well worth it) - dont bother gapping these plugs below the standard 1.1 unless you are running higher boost.
3) If your plugs dont fix the problem, my next step would be to replace your coil packs. This leaves you with 2 options in my opinion.....1) you buy Just Jap coil packs for around $399..... or you buy Splitfires for around $485 from Slide.....
With my experience...I found that Splitfires made my car run very smooth. but as i have heard nothing about JJR coilpacks, i cant really make a call on how well they work when compared to SF.....
Let me know if you need a hand with changing the spark plugs/coil packs as i would be more than happy to help...Sundays are a good day for this :whistling:
Cheers.
i would NEVER run 1.1 on a boosted car.
i ran 1.1 on 10Psi on my old GTR and it wouldnt rev over 5500rpm the misses wer that bad.
regapped by hand the platniums to .7 and took for a drive and hello 9000rpm gate :D and fark it got its bucket load of torque. i remember that day as thats the first time i wet myself in that GTR :whistling: and blew a cooler hose off. on 10psi haha
+1
regap them man to the recommended gap of 0.6 or whatever it is.
u can only leave at the stock gap if u have a crazy ignition system or using a nos system. splitty coil packs or other similar coil packs are simply not up to the task. for that kind of ignition we are talking a dedicated msd coil pack with spark lead. but thats an easy $2k right there.
+1
+2 on the plug gaps. I think from my previous experience you will need no more than .8 gap.
If this doesnt help split fires are good, unless you are chasing 500+ hp they will do fine.
sup guys got a question for ya. put in a new o2 sensor, and have adjusted fuel prs to 40psi, and running super rich :w00t: for once.
ive been runnin 8psi for a few months now, because if i boost over 12 it gets guttless and hits the wall.
now that ive richened it up, can i run 14psi well?
hoping it will work sweet now my afr issues are fixed seen examples with ppl running 14+psi on stock car and reaching 300hp. :cheers:
dont worry about turbo probs/ constantly ran 20psi ages ago.
Dunno if this helps, its a long read but might be the problem.
http://www.skylinesaustralia.com/forums/R3...Gt-t196124.html
sup guys got a question for ya. put in a new o2 sensor, and have adjusted fuel prs to 40psi, and running super rich ;) for once.
hoping it will work sweet now my afr issues are fixed seen examples with ppl running 14+psi on stock car and reaching 300hp. :rofl:
if it is the stock computer then the wall you hit is the richen and retard stratergy of the computer, once you reash a certain level of air flow the computer retards timing and dumps a tonne of fuel in hence why you go slow! Upping the fuel preassure will only make it worse and hurt your wallet fuel wise
YESSSSS!!!!!!
FK skylines bro.
go a rz supra with 2jzgte vvti.
wack in a t51r.
3 fuel pumps, surge tank
or better yet keep the tt setup. :nyaanyaa:
skylines are a good learner car. but if u want serious fun go a rz supra
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
