i had some stupid kids try that receipt trick on my car, where they put the receipt on your back window and when you get out they jump in and drive off. thankfully i was smarter then that and took my keys with me. so when they came near it i told them i would kick there ass if they went near my car again.
some people really have a nerve. so anyone know of any good alarm systems?
there black now. and yeh she is stock except the muff. let us know how much and ill check out my finances. my 18th is putting a pretty hole in my pocket at the moment lol. because i have rego, insurance and a party to pay for...its good fun. but let me know and i might hold off the trial body kit for anotehr month.
you can have the zorst for $120
In otehr words ill get it, but ill have to check it out first is all.
Just watch if the exhaust came off a coupe as the sedans are longer by about 60 to 70mm and the exhaust might be short, simple fix thought just get it extended.
I saw a guy from sau fit a exhaust the other day to a sedan ( one of the kit full exhaust of the net)and by the looks of things was supplied a coupe and he ran into drama's with the rear muffler sitting to far in and too close to the bumper which in time cause it to burn the bar.
yeh i know all about that, but dattoman knows i got a 4 door so he would know if it would fit or not. thanks for lettingu sknow thou
not unless her measured it and knew the length of a coupe and sedan exhaust,but good luck if it works sweet
Also not sure if 33's are the same as 34's but my sedan i got a nismo brand muffler and it apparently had come off a coupe but to fit the sedan it needed to be extended as mentioned above but also new brackets put in place as the fitment was not in the same location as coupe.
yea that was me.
should be getting zorst extended next week.
Hey guys,
Just a quick heads up - we have a BBQ and Cruise happening this Saturday morning. EVERYONE is welcome! (we have 50+ names down to attend)
I know a few guys from the gold coast are head on up. Anyone planning to come down from the sunny coast?
if anyone is coming down, can one of you guys organise a meeting point so you guys can cruise up together?
We've got a breafast BBQ happening - arrive at 9am, start the cruise at approx 10.30, ending with lunch at the pub 12noon. For more info, check out the post in the event section -- here
an early start for you guys, but should be a good day!
well i dont know but im sure none of the guys actually read this in time and if they did they probably are already there. i cant go car is getting fixed, but sounds like a good meet up. P.S best place for sunnycoast ppl to meet for events is ettamogah pub, its just off the highway and is fairly central to everybody to go to meets.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
