well i went drifting last friday nite (31/7/09) at QR. it was awesome fun. the only thing i broke was my speedo cable. pretty stoked with how tough the car was. was wondering tho has anyone else from up here gone drifting down there. my clutch started to get smelly by the end of the night. was wondering what other guys use from up here. i dont wanna go a twin plate or a triple plate. i dont want something really dera either cause it gonna cop i thrashing all the time. any advice would be good
Yeah we took a few cars down. Got my missus out on the skid pan in her 32 for her first time. I will be out at the next one in my car.. havent driven in over a year so gonna be interesting!
ill be there, car will be running well again to :P Will is ur car sitting at martys? I was there last week i think it was and a red r33 similar to the one in ur avatar was there
Edited by r32na
3 days? im sure its only 2. the back car park is the place to go, that front one is just stupidly full and slow, and the back one is closer to the track :D
if you are going for both days, make sure you buy your tickets online, as they will not be selling 2 day passes at the door this year
I'll be up sunny coast this weekend. Going to play poker on saturday night!!
Then going ice-skating on sunday. If you're bored on sunday, you should come!! Boondall Ice World!
hey dude, where u playing poker????? sands tav is usually pretty big
sweet. what do you drift. im drivin the blue 32 with gold rims. the next nite is on 28th of this month. i cant wait. christmas comes for me once a month. be good to see you down at qr.
thats another car. its been there for about 2 months. the guy was building it up to be pretty sweet but hes run out of money so its just a big paper wieght at the moment. bit of a shame cause hes already spent a few dollars on the good stuff.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
