Yeh i might aswell give it a try, cheers. Ive been told by marty and some other guys thats its very unlikely to be the AFM, just because of the seriousness of the problem, do you have a computer to suit a n/a rb25 by anychance aswell lol?
na man, its goten alot better tho. I've ordered a loom from justjap, and ill try blue32s afm aswell... if theres no difference ill take it to marty when he gets back to work from his holidays.
Hey any of you guys with bikes wanna come along on a cruise tomoz starting from beerwah high school and heading out to kilcoy??
It leaves at 10am so if anyone is keen let us know, or just turn up! haha
Ok, I've decided I wanna head over to one of the Thursday night meets at Baskin-Robbins up at Chapel Hill. It would be good to organise a meet somewhere (possibly the ettamogoah) and have a bunch of cars head up together.
I think they ususally meet around 7pm so we would have to leave a bit before 6 as it's a bit over an hour's drive.
It would be good to meet some fellow members and have a nice ice-cream at the same time :)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
