hey iv got a r33 gts=t and wana tidy up the frount lights and make it look nice is there and after market lights i can get or a clear plastic to replace the old lens and what is the price on a new pair of frount lights for a 94 model r33
https://www.sau.com.au/forums/topic/140772-head-lights-r33/
simple fix, got some cut and polish and cut the plastic, do this a couple of times, by hand, and depending on the grade on the cut polish, either do it up and down, or across. Then use normal polish a few times, and no probs, nice and clean.
Just a lot of elbow grease
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2622822
Often the main smoky problem is on the inside of the lens - which means you need to carefully heat your lights in a normal oven to a certain temperature, at which time the rubber seals let go and you can separate the cover from the rest of the light to polish the inside.
Meguires make a great plastic cut polish that made the outside of mine look 100% better, but I really ned to do the insides too. I think there is a tutorial on how to open up your lights somewhere on SAU - do a search.
I have seen as new paris of lights go on the forums for around $1,000 from memory - new from Nissan expect $1,000 each!
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2623052
Yeh true that Andrew, I have that Meguires stuff, and it really does work a treat! Well worh the money!
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2629572
to remove the lenses of an R33 is a delicate job u need a heat gun and a steady hand ( oh and hours ) lol
unclip the brass clips then on a hot day use a heat gun to heat up the silastic until the plastic lense comes off then spend hours cleaning the c#$@ off the lights and lenses, wammo done
i just painted the inside of mine cleaned the bugs out and used the maguires clear plastic cleaner and went to town on the clear plastic lenses, inside and out.
put it back with ample amounts of black silastic and they looked like brand new ones,
hope this helps
P.S a mate just bought a HID kit off ebay for $200 comes with 8000k globes and transformers. They work wicked and look great too.
mike
Edited by trick
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2630995
so how much would the chrome 1s cost me and im getting a custom bonnet next week if i get a series 2 bonnet do i have to get series 2 lights and is there much diffrence and if any 1 has r33 lights for sale plz pm me as i need them asap
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2634211
easiest way to open the lights is to put them in boiling water and pry open with a flathead screwdriver.
then clean however you want.
I did Vange's lights by using vx calais projectors and silver surrounds and cutting them to mount in the existing hole.
looks awesome.
just need those projectors before you use xenon HID lights otherwise they look like street lamps.
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2634539
yeah don't I know it mate - my headlights are so damn bright I have people flashing me all the time thinking my high beams are on. I have ordered some eyelids, and if that doesn't fix it enough I might do what you did, but with some Accord Euro projectors ....
Saw you the other day - why have you got your VW beast for sale already?
https://www.sau.com.au/forums/topic/140772-head-lights-r33/#findComment-2634746
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
