:D
HI. ive got an R33 and for the last 8 days ive been having probs with excelleration. When i take off the car feels like it is pulling back. It is really hard to get ay boost and when i do it comes in dangerous short bursts. I thought it my be fuel tampering (scabby servos) so i let it run dry and went to anoher shell but its still happening. I'll be drving and will try and put my foot down and get no power then all of a sudden, i get, as i said, a shor power intake and it is quite dangerous cause it will happen when im right behind another vechile.
So if anyone out there has any suggestions i would more than appreciate your help as im so worried about my princess....
Thanks in advance
Gem
Edited by princess01
:sick:
Thanks in advance
Gem
I had similar problems with my last car (silvia turbo). Cleaning the air flow meter helped (take it out, run some metho over the element that sits in the middle of the afm (do NOT touch any wires with your fingers), let it dry fully then put it back in the car). Not sure what the problem was exactly. It seemed to do it more in hot weather or after the car had heated up a bit.
The reason cleaning my afm helped was because I was using an oiled air filter (k&n) and they tend get oil all over the element in the afm. I changed back to a dry air filter and had much better results. Cant say if the afm was the problem. I suspect the problem may have been elsewhere and just made worse by the afm reading incorrectly.
Other suggestions might be to check the fuel pump?? dunno.
Does it seem to accelerate ok up to when you'd hit boost? Does it stutter or just really bog down and you get nothing? In my case the revs would build up slowly and it would seem to pick up a little but it was terrible. And only after 15-20 minutes or so of driving. Often I could turn the car off then back on and it would be fine for a couple of minutes.
Hi, It might help if you list any mods (if any) on the car that you are ware of.
One of my mate's personally imported a series 6 RX-7 & it ran like crap because it was tuned in Japan to run on their premium fuel (108ron?). A simple re-tune on the dyno fixed it right up & it runs beautifully now.
has the car been previously owned in australia or are you the first owner?
Good luck with fixing your car & hopefully someone on here has an answer for you.
Hi,
There are no mods at alll on the car. It was owned in aus before me. Thanks for the advice. Ill give it a go
So... when you give it half throttle, it stutters? Or it drives normally but with no boost? When the boost comes on, it shouldn't launch you TOO hard on a stocker. What does the boost guage read when all this happens?
How far are you putting the boot in?
If it IS just the boost, and not a fuel or coilpack or whatever problem, then maybe you have a sticky wastegate actuator? You'd have to be gunning it and not just normal traffic driving to generate that much boost that you feel it though.
she did say it happens when shes taking off so its not the common misfiring problem.
it could be your:
CAS
AFM
spark plugs
coil packs.
do the spark plugs if you havent already. take your AFM out and spray with carby cleaner. do my coil pack fix, and try swap your CAS with someone else with an r33.
if you can get your hands on someone else's CAS, then do that first.
if you were in syd i'd be able to give you a hand.
Sounds to me like misfire
Does it happen around 4000/5000rpm onwards?
hi ta for your suggesstions. i took it apart and it is the coils. one cover is broken. YEAH!!!! not the thousands of crap that i thought it may be:)
ta gem
Check sparks, check coilpacks for hairline cracks, clean afm?
Does "sound" like the common missfire problem that nearly every line owner has.
ta gem
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
