Kris, (krzysiu) had this same problem (and judging from the location probably the same officer in question).. I think from memory he had to pay $600 for the engineers cert, the car also had to be put back to stock first (I think).. Have a chat to him about it.
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2629885
black intercoolers with black piping and silicon work well, it's stock officer.
not when the cop clearly knows exactly what he's looking at. and knows a hole has been cut to fit the AFTERMARKET cooler.
only way to go? Blitz/ARC all the way. Not so expensive when you get hit with $600 for engineering + any other expenses :D
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2630186
As long as you havent cut a hole through the chassis rails for the cooler return pipe it does not effect anything in the front end of the car.
I got done ages ago for this same BS but didnt need to get a engineers certificate or any other bs, just a rwc, where nothing was changed anyway.
Car does not have to go back to stock if the cooler is the only mod
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2630197
But hey. When Holden crash test their cars they dont have huge bullbars on the car. But they are fin if they want to run them.
But god help us if we saw cut a 63mm hole in a non structural panel. All of a sudden our cars are going to kill us in a frontal.
Easy fix. Get a bit of 6mm round bar bent up and welded to around the hol eyou have cut. The primer and paint the whole thing...rock up to your engineer and you should be fine.
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2630204
Not being a resident of Vic, who is the opposition leader. Seriously, write a letter from the honest car enthusiast asking whether the focus of the police and road safety campaign will continue ot focus on modified cars. Sure target silly and dangerous mods, but i dont want to hear that my brake upgrade is illegal, or my filter and cooler makes me a menace.
I have never had a problem...but seemswrong that others are
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2630232
spoke to a few enginners. some will only rip the cooler out and patch the hole with a plate. some wont touch it because it comes with air bags and by cutting a hole the air bag may possible act different in a front on crash. and some will strengthen the hole and sign it off.
thing about engineers cert is that its for the whole car. so anything that didnt get picked up by the cops will by the report. so my exhaust db, ecu, wheels, ride height all has to be fixed too.
its gonna cost bout 80 bucks to strengthen the hole then its 350 for the cert. so thats not too bad. but thats if the rest of the car is ok. im pretty sure it was in an accident in japan cos the key doesnt fit the drivers door lock. so hopefully its repaired properly.
if only i got one with the return pipe going back in the original spot. what did you pay for urs dezz?
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2630321
I recon the engineers are in on the scam with the cops. They prob split the profits 50/50
i recon your right there. think vic roads is in on it too. because theres only a select few vic road approved engineers.
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2630328
I got defected in knox to june 2004
Left my car sitting in my garage for over a year waiting till i got off my p's, spent $4500 getting it roadworthy again.
I needed an Engerneering cert for my rear parcel shelf which had holes cut into it to fit 6x9 speakers.
Costs me $480 to fix the holes, $320 for the cert (plus another 60 for 2 replacement child restraints)
2 new tyres was $365
Scraped through the RWC test (cars lowest machanical point was 101mm off the ground.)
Plus my 100,000km service which cost me close to $1900
Then had to worry about getting my car registered again.
Haha no point to that story but the guys I delt with for my cert were really good they in the approved vic roads list to.
They are just off burwood hwy near lewis road if you know it.
Can get ya the number if needed.
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2631396
only way to go? Blitz/ARC all the way. Not so expensive when you get hit with $600 for engineering + any other expenses :rofl:
:P thank god for the BLITZ coolers i'd be coolerless without them
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2631515
how do you know that you have to get an engineers cert? Like I'm sure the officer in question told you that you would have to....... but is it written down anywhere? has your rego actually been cancelled.. becuase if it comes down to a Vicroads inspection... well we all know what vicroads are like.. you might just get away with it.
https://www.sau.com.au/forums/topic/141205-defected/#findComment-2634213
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
