Recently i have been seriously looking for a bigger turbo for my car, but wasn't too keen on the lag factor. My aim to to acheive 280-320rwkw, but i would like to keep it's drivability.
B4 i go on: i have done a comprehensive search and wasn't able to find anything on this issue, so please if you know of a thread post it up below.
For those in the know i would REALLLLLY appreciate your input and advise, i am all "ears"!
My idea is to replace my turbo and manifold with a twin turbo setup (gtr style). By using 2 smaller turbos (350hp each) this should, i think, produce about 400kw at the crank.
MODIFICATIONS (Things i know that need replacement):
-New manifold (Can a GTR manifold fit on the RB25det head?)
-Custom front pipes
-Dual oil/water cooling lines for turbos (can the original line be split into two to cool both?)
-Custom intake pipes (from filter to turbo and from turbo to fmic)
CURRENT MODS:
-Wolf 3D V4.51 R33 Plugin
-Fount Mount Intercooler
-Cold Air induction (Pod in sealed partition with 4" drain pipe feed from front bar.
-Adjustable boost
-3" hi-flow exhaust system from turbo
-H/D clutch
MODS TO BE COMPLETED WITH UPGRADE
-550cc injectors
-bosch fuel pump
-bosch fuel regulator
-Ceramic coating of all piping (ex. manifold, intercooler pipes, turbo cover, plenium, exhaust from turbo to cat., etc)
-ADJ. ex. cam gear (optional)
QUESTIONS:
-Is this project possible and financially fissable?
-Which turbo's would best do the job?
-Any other mods that you would recommend doing (cams, etc.)?
-Has this been done B4?
-How does the GTR manifold work? Does it use 3 cylinders per turbo?
-Any other information/points are most welcome.
Again, i would REALLY appreciate everyones input and like to say
THANKS in advance.
ALAN C.
https://www.sau.com.au/forums/topic/14153-hlep-considering-bulding-a-rb25dett/
OK high power and lag go hand in hand un less you increase capacity sso you want 280-320 rwkw with boost down low the best way to do this is with an rb 25/30 motlowth on hearhas a similar set upto what you want and thats how he did it the twin turbo's are possible but you will still have lagg.
he is making 310-320 rwkw @ 1 bar full boost by 4 k rpm I believe
meggala
btw go to my web site and read the mods section It might help
Hi Nismo_Boy, how about we cost this idea...
MODIFICATIONS
-New manifold $1200
no a GTR one won't fit.
-Custom front pipes $800
-Dual oil/water cooling lines for turbos $300
-Custom intake pipes $400
-550cc injectors $800
-bosch fuel pump $500
-bosch fuel regulator $300
- Ceramic coating of all piping $700
- ADJ. ex. cam gear $250
- 2X hi flowed RB25 turbos $2200 each
- Dyno tune $400
That's a nice round $10,000 but the RB25 internals won't handle 320 rwkw, so you will need...........
- forged pistons $2000
- conrods $2200
- balance, gaskets, seals, o'ring block say $1800
- oil cooler $900
- radiator upgrade $1000
- camshafts $1600
- porting of cylinder head $700
And that totals $19,850.
When do you want to start?
THANKS FOR ALL YA INPUT GUYS!!
Looks like i need to go back to the single turbo idea, as the deal with NISMO_BOY may fall through. It was pure coinsidance that he was selling this setup at the time i posted this idea. But i consider $4000 for basically a block, manifold (modified rb26DETT) and 2 worn turbos a bit rich, not to mention risky.
But now i am back to my original delema. What turbo will best do the job and has the least lag? I am under no illusion that i will get more lag, just want the best package.
MODIFICATIONS
-New manifold $1200
- Dyno tune $400
- conrods $2200
- oil cooler $900
- camshafts $1600
Why would i want to start, when i can just buy the one im selling for $4k
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
