Yep its definitely difficult to slide on especially if the attachment has a lip of any sort.
Grab a rag and smear on some rp7/wd40. Works quite well.
Just don't go overboard as wd40 i'd imagine isn't too good for the oil. :(
Connecting it to the motor is difficult and you will end up feeling like your going to break your forearm pushing it on.
Cut the oil drain off so that its straight, thats what i ended up having to do as mine too was on an angle or does it angle from the start of the attachment? :S
That bit of hose I gave you was the softest stuff I found in that size. The gear I got from pirtek was very very solid.
haha, i shouldn't have posted this in this thread, oh well!
The problem i'm having you see is that my oil drain isn't directly at the bottom of the turbo which causes more headaches with the angle that it is on, i have already chopped it shorter as i used the xr6t oil drain with a new tube welded on. Because of the angle the hose has to bend into an 's' shape which just crimps it and only the cheap shit i have seems to wanna bend without crimping!
Ahh ok so the centre cartridge wasn't unbolted and moved so that its 'square' if you like?
Have a look in the sticky there's another rubber hose bloke who deals with only hoses. Pop through there and see what he has.
I was really after just a nice rubber oil resistant hose like stock uses but Adelaide hose and belt only had the pressure stuff that tends to be a little stiff.
Speaking of which, anyone know where I can get silicone intercooler hose piping? I want 3" stuff but everyone just sells couplings that are 3" x 3". I want a longer one, about 5" long instead. Sorry for the hijack.
i thought only the 2 housings moved and not the centre bit?
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
