Hey,
I am new here and interested in buying GTR33. Have couple of questions:
1) Where should i look?
2) Should i import or buy in AUS? (Which is cheaper?)
Any advice you might have would be greatly appreciated.
Thank you.
P.S. was looking at http://www.j-garage.com/sale/usedcars/stoc...ock/110571.html
https://www.sau.com.au/forums/topic/14159-looking-for-advice/
j-garage is in japan/america, look at some local dealers. prices for america are usually a bit pricey.
I'd reccomend www.j-spec.com.au if you're patient enuff to get it. I've got an GTS from them and am in the process of getting an R32 GTR from them. Saving me quite a bundle.
thats it, after you get the car from japan you comply it (which takes 1-2 weeks depending on who is doing the compliance and how busy they are)
then after the work is done it has to be signed by an engineer the it takes about 1-2 weeks to get the compliance plate. then you register it.
but it'll probably take longer under the new scheme.
Ok, thanx for your help :D
Don't be in a hurry if you're importing.
I began the importing process for my R33 GTSt sedan just after Xmas & the car finally arrived at my place last week.
It's in good conmdition & there weren't any big nasty surprises, but be prepared for a lot of stuffing around if you're importing it yourself.
Also allow extra $$$ because mine has ended up costing $2,000 more than the import broker told me to expect.
Good luck.
PS: The car's great & will be fully rego'd & legal on Thursday.
WOOOO HOOOOOO!!!!!
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
