White , just been bought in , has some goodies ie.
Cusco coilovers
ARC airbox
18x9 BBS wheels
Kakimoto computer
HKS blowoffs
Greddy oil cooler
underbody bracing
Nismo rear arms and Nismo caster rods
320kmh speedo
also have extra parts here in WA that were removed prior to shipping for compliance such as
1/2 cage
Recaro drivers seat
4 x defi gauges
LOUD exhaust
Big arse aluminium wing
Has 50K on the speedo but suspect about 80KM and has minor accident history.
Probably one of the last GTR's avaliable from Japan for a while.
Priced for quick sale at $26,500 complied but not lic.plus extra parts
Car is in Sydney for next week to be complied and then coming back to WA.
Contact [email protected] for more info.
Cheers
Ken
https://www.sau.com.au/forums/topic/14163-r32-gtr-1992-fs/
Originally posted by skyline33
Ken,
would you be intrested in swapping for an R33 GTST  series II
err , no and it is a 1992 as per the post at the top.
Cheers
Ken
https://www.sau.com.au/forums/topic/14163-r32-gtr-1992-fs/#findComment-286045
Originally posted by memphis
gimmmmmmiiiiiiiiiiiiiiieeeeeeeeeee!!
once it arrives in perth ill check it out, if its in good nick, ill have it!
depends what you mean by good nick.
If you want a one owner , low km , std GTR then you should have bought the gunmetal grey one I sold Simmo.
That was a damn nice car and he got it for a bargain price.
Micko also got a very good deal on his.
This is some sort of drift type GTR from Japan and as you can see by the parts it has been used.
Also has an evil twin or triple plate , super grippy clutch and a very noisy 1.5 type diff.
Cheers
Ken
https://www.sau.com.au/forums/topic/14163-r32-gtr-1992-fs/#findComment-286054
Originally posted by initialD
ken, wat type for minor damage?
Repair on RHR 1/4 and a repaint on the bonnet.
Has minor scratches and nicks .
Also the rhr skirt needs repainting cos the painter stuffed up the touchup.
Cheers
Ken
https://www.sau.com.au/forums/topic/14163-r32-gtr-1992-fs/#findComment-286059
Yes but there are guys on this forum who are based in the East can do it just as well.
Try Craig from J Spec and there is a guy in Qld who's name I forget with a good reputation.
Cheers
Ken
ps The cost of compliance on R33 GTR's atm is around $7500 now.
https://www.sau.com.au/forums/topic/14163-r32-gtr-1992-fs/#findComment-300252
for those interested in this car;
Ken is an extremely honest and trustworthy guy, if i had a chance to, i wouldn't think twice about buying a car off him!
Christian
https://www.sau.com.au/forums/topic/14163-r32-gtr-1992-fs/#findComment-301654
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
