As the title states I am looking to sell my turbo gear as unfortunately :yucky::sick: the set up won't work with an RB30 bottom end as the turbo sits to high.
The manifold has the larger runners compared to any of the other cheap manifolds - it also lines up perfectly with all the head ports. As the photo's show the manifold is very well built!!
The turbo has a 0.82 rear, has done in between 5 - 10,000kms and still seems fine, compressor cover is polished
The wastegate is a tial 48mm US made wastegate of very high quality - would consider selling setup w/out wastegate if anyone is interested.
Also comes with water and oil lines off my RB25DET - done about 5000kms,
Looking for $2600 for a proven setup
PM or call me on 0417 438841
Edited by turbo87
hits full boost around the 4000rpm mark- this will depend on alot of things tho as my motor was only running approx 8.5:1 comp, a standard motor should hit boost earlier,
Yes may sell turbo seperately so make an offer.
Cheers,
Paul
Bump
Will accept $2600 for the lot
May consider selling the dump pipe with it - pickup only
Edited by turbo87
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
