On my 32 gtst this light keeps commin on (see pic below) the owners manual doesnt say what it is, just names it 'Exhaust Gas Temperature Warning Light' and says if it continues to stay on contact a nissan service dealer! Obviously it has something to do with the tempertaure of the exhaust, just wondering if anyone knew anything about it? I have stcok exhuast! Any help would be great!!!
Cheers,
Tyson
Edited by kingy_06
https://www.sau.com.au/forums/topic/141789-help-please-asap/
Maybe there's something wrong with your catalytic converter?
Or the sensor isnt even plugged in?
(the sensor will be plugged in to a spot halfway along the exhaust)
Maybe get under there and have a look :pirate:
From my knowledge your O2 sensors are only on the dump pipes. Could be a third. That light does work in conjunction with the diagnotics LED on the side of the ECU so could be something to do with that. Altho it usually flashes when your in diagnostics..
Cheers,
Tyson
The manual has answered your question. (when I went to school, "naming" something and "saying what it is" were synonymous).
It is a warning light. It means something is wrong. It even recommends what you should do - see your local Nissan dealer.
It comes about when the temperature of the exhaust gasses passing through the catalytic converter (nothing at all to do with O2 limits and closed loop operation!) reaches a certain limit (measured by a thermocouple in the converter's body). It is possible that the engine is beginning to run too lean (maybe due to dying fuel pump), or maybe the cat is collapsing and blocking the exhaust.
Go see a Nissan dealer and get it sussed out.
Do you have a Power FC?
Theres an option in the Power FC commander that has been turned on/off (I can't read Japanese) so it thinks there a problem-o.
No real conclusion when I had it, so I forgot which option it was
http://www.skylinesaustralia.com/forums/in...=125541&hl=
was just thinkin and i did make an adjustment to my idle over the weekend and did do some fine adjusting on the idle screw on the side of the ecu! Dont know much about ECU diagnostics but isnt the first mode an exhaust tempertaure mode or somethign like that? Does anybody have any knowledge in regards to that?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
