gday guys, well i have an rb26 that requires a rebuild. the engine is out and has began to be stripped. so i will be using this thread to get as much info as i possible can. i am aiming to build to make reasonable amount of power out of the engine
the first this i really wanna knkow is about the N1 oil pump. i have been told not to use it as the have been failing people. and also that it will cause a ruch of oil flow to the top end causing the bottom end to be lacking in oil.
will the oil galleriy orifice help this problem?
and any help with this first issue will b much appreciated
cheers guys
https://www.sau.com.au/forums/topic/141933-my-rb26-rebuild/
hundreds of people are using the N1 pump without problems
Keep your rev limit to a sensible limit and you shouldnt have any problems
If you arent afraid to give the thing a hiding and want more 'peace of mind' then start saving for a Jun pump but expect to pay a little over twice the price of an N1
https://www.sau.com.au/forums/topic/141933-my-rb26-rebuild/#findComment-2643347
are you building it yourself, or are you getting someone else to assemble it?
If ur not doing it urself, first thing is to find a good builder who u can trust, and talk it out with them. Ask what they know, and have done in the past. Then you can move onto more specific questions :)
https://www.sau.com.au/forums/topic/141933-my-rb26-rebuild/#findComment-2644335
just wonering if anyone has a picture or some specs on the oil gallery restrictor/orifice used with the n1 oil pump
cheers
Pleas use the search function mate.
Also read the sticky thread, Forced Induction Guide.
There are lots of things already covered in 10+ page threads with more information that you'll ever need.
Oil control, bottom ends, top ends etc have all been covered quite extensively in the past, so asking them again really doesnt do the people justice who took the time to post detailed information before :)
https://www.sau.com.au/forums/topic/141933-my-rb26-rebuild/#findComment-2644479
my car is at a work shop but the are concerned about the oil control and think that i will drop another bottom end. the are a very repitable performance shop and ask me to do a lil researsh into a few things to help me make up my mine as the are flat out.
yeah i have read sydney kids forum on oil control.
there are things i would like to know.
i have been told that there is almost a 50/50 split with people using N1 oil pumps saying the they work or fail, can someone help with this?
will the early model r32 gtr cranks still leqave witness marks on the n1 pump if they have been collared?? or will it be a better idea to get an r33 gtr cranks if possible?
https://www.sau.com.au/forums/topic/141933-my-rb26-rebuild/#findComment-2646440
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
