FOR SALE 1992 R32 GTS-T
ENGINE: New Low Km engine (RB20det) still under 3 month warranty, with receipt!
ENG. MANAGEMENT: Microtech LT12s with hand controller
FUEL SUPPLY: 33gtr vspec pump, sard 555cc injectors
BOOST CONTROL: Blitz sbc the one with dual solenoid(the good one! :)
COOLING: Hybrid cooler and piping kit, also BRAND NEW cooling pro radiator with receipts!
TURBO: HKS 2530 rebuilt with 2835 internals
CLUTCH: Brand new Xtreme Xtra Heavy Duty 6 puk clutch kit, with receipt! cost $$$$
DIFF: New diff, with receipt from wrecker (had 2 way in it)
SUSPENSION: TEIN HR Rebuilt coilovers, done not even 500kms Adjustable front and rear castor
WHEELS & TYRES: 18" AVS MODEL 6 18x 8, 18x 9 +35 with Brand new Firenza 235/40 fronts,(receipts)Wanli 235/40 rear
PAINT: Custom paint full respray earlier this year. $3300+ worth of receipts for paint job ALONE!!
OTHER: has vertex front bar, has hybrid intercooler setup, new battery, autometer oil pressure, boost guages, momo course steering wheel, full 3"exhaust with 5zigen muffler, darkest legal tint possible. Can throw in old engine + heaps of spares if need be. I.e. standard r33 and r32 wheels.
$16,000
Edited by HRthirtyone
https://www.sau.com.au/forums/topic/141941-92-r32-gts-t-reliable-2xxkw-setup/
  • 1 month later...
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
