Back to the begining, must be the inj or ECU tune if fuel connections OK.
Have the Inj been recently flowed or tested for thoughput - I left mine on bench for two months and would not work as gummed up inside.
Are they ticking or actuating that you can hear with a screwdriver on them on your ear? Check plugs for wetness of fuel in each cyl if unsure.
Maybe ROM tune is out in timing or fuel maps on start.
Are you getting any error codes from ECU?
NewKleer's LCD Consult just diagnosed my problems via datalogging software that told me the timing was advancing to 60' BTDC at 3000RPM on the road.
Hold a screw driver on the injector and listen to see if its ticking when cranking, if it is then its a fuel supply issue. Take the fuel feed line off and make sure it purges when on reders. Does it attempt to kick at all? If it does not then I would assume the injectors are not firing what so ever which should indicate a wiring or EC tuning issue as already suggested.
Have you used the correct impedence injectors right? Also after cranking can you smell fuel?
If you can smell fuel than it may be another issue entirely like spark.
The AAC unplugged wouldn't cause the car not to start though.
Maybe start then stall if its adjusted incorrectly but nothing a little press of the accelerator couldn't get going.
is that cause AAC is normally open (and therefore ull get a really high idle is disconnected?)
The idea is to set the aac valve so that idle is 650rpm (R32) with the plug disconnected, with the plug connected (solanoid) its used to raise idle when needed (powersteer, a/c & prevent stalling etc)
The solenoid shouldn't be relied upon to get you your 650rpm as this is when hunting occurs.
If its wound all the way in and the car won't idle the car will still start but stall.
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
    • Oh sry i do not know if i used the term right. What i meant is upgrade the internals and keep the housing. That is not "hybrid"?
