HI all,
Im wondering if the 6 ITB's from a RB26 (?) can be fitted to suit a L24e, as i think it would be a challenge and rewarding upgrade.
I will probably use a large plenum th house 6 'trumpets' and an intake with the AFM at the filter end...
Dont know if the stock computer could handle it but....
Post away! :D
HI all,
Post away! :blink:
The RB26 intake system fits on an RB26 head ONLY! similarly the GTiR quad throttle body doesn't fit on an inline (RWD) SR20.
Nissan made them that way or a reason I suppose.
You want to do this on the cheap, middle of the road or cost you a bomb???????
Only motor easy install into an MR30 is the L24E out of the MR30, everything else needs some amount of engineering and unless you have a workshop at your disposal, it's all going to cost lotsa dollars.
Try doing some research like most of us have done before you before asking crazy questions. You tend to learn more that way.
Cheers, D
I didnt think it would be a good idea....
I just was thinking of options to increase the power in the lower revs...
I am hopeing to keep this L24e because it has such low km, and is amazingly smooth... ( i like the EFI too, not fussed on carbies)
I have stacks of questions, most which are probably pointless...
Can anyone direct me to a thread or some articles on modifying the L24e? the search feature isnt that helpful...
Are there many hotted-up L24e's around?
sorry to sound like such a noob
Try to find yourself an N42 head (early 280ZX) and get the head worked over by someone GOOD! change the cam, put probably 280ZX injectors, decent set of extractors and free flowing exhaust should up the anti a bit, but your really only going to gain maybe 10Kw.
If you want to keep the L24E and turbo it, you need to find an L20ET exhaust manifold, probably a T03 off an FJ20DET and a piggy back ECU to control the boost & fuel. This will get you about 140Kw on 10psi, considering when stock it has 93.4Kw. The late model L24E's were good to turbo, can't put big boost into them as the static compression is over 8.5:1, but you can get good gains from staying under 10psi and be safe and reliable.
If you do it smart and use a plumback BOV know one will know what you have until it's probably to late.
Cheers, D
Actually they will. GTR TB's are 45mm and the butterfly spacing is almost identical to DCOE weber/mikuni/dellorto. Of course the mount bolts are different, but 'all' that is needed is an adaptor plate to a triple carb manifold similar to the one shown in the photo below, plus some mucking around with linkages. Anything can be done if you have access to the equipment.....(but I'm not saying it would be cheap if you don't)
Oh and BTW, interesting to see old ideas being recycled. I've had a custom injection manifold (my manufacture) almost identical to the one shown in your photograph on my Z for the best part of 15 years with Motec control. There are far cheaper ways to do the TB's than those custom jobs, plus its better to mount the injectors at the mouth of the trumpets.
No they wont but these will...
I thought an adaptor plate would do it, thanks buddy!
Would there be a noticeable increase in performance?
I would rather spend a few hundred dollars on a N/A set up than a half arsed turbo...
I guess it comes down to dollars, and the tuning of a good ECU (or piggyback)
I think I saw a gtr setup for $150 a few weeks ago... apparently its one of the first things to go on big HP engines...
Th first thing I am going to fo is get the injectors cleaned, new sparkplugs and leads, and look for a good head to port out... ANd then we come to the intake system! Are those twin pipes that cross the radiator beneficial at all? should i duct a shorter system into the bumper?
A few hundred dollars on a n/a set up?????
My original project started with the idea of getting 300+ HP to the wheels in an n/a RB25 or 26/30DE.
The number of research hours that went into this original project was staggering.
Our end theoretical result, after many long hours of computer calculations went to about this:
RB26 Head & Inlet system, RB30E block, RB26 crank, custom carello rods, forged pistons, 330/340 degree duration cams, a staggering 14.5:1 compression and to acheive the objective the engine had to rev to just under 15000 rpm.
This project was debated on SDU for weeks on end and some of the brightest engine people I know were involved, just so that you know it wasn't just some hair brained scheme.
The RB26 crank was the chosen option because the RB30 has non balance related harmonics problems at 7500 and continued over revving would result in a bent crank. And doing a rebuild after every run didn't impress me at all.
After all the sums were done, the estimated dollars to acheive this goal was in excess of $50000.00 and it wouldn't idle under 3000rpm, so in 4th gear at idle it would be cryuising along at about 100kph. I'm sure our local law enforcement officers would have been impressed.
The moral of the story is this, NO HP IS JUST A FEW HUNDRED DOLLARS.
A good ECU, motec, EMS, WOLF etc etc is going to cost about $1500.00 plus the cost of wiring @ $70 per hour.
Port & polish a head, another $3-500.00
An adaptor plate for the 6 TB's ..... the skies the limit on that, maybe you should enquire about it at a machine shop.
A GTR setup for $150, what was wrong with it, is what I would be asking myself?
A new billet camshaft from Camtech was quoted to me at $350.00
Just how much money do you have to sink into this project? This is what you have to consider before anything can be researched and after you get the power increase you want, along comes bigger brakes, better suspension etc etc etc. A new sway bar from Whiteline is about $260.00, Koni's all round with King Springs and away goes a grand, so just in suspension upgrades you have spent over $1200.00 and the motor is yet to come.
Cheers, D
All that for just over 300rwhp??? You'd be looking at a hell of allot more power than that with an RB26dett in on an rb30 block, especially with that much attention to detail... I honestly doubt I'd know what I'm talking about as much as people like you when it comes to engines and realistic power outputs but shouldn't you be able to get a good 300rwhp out of a stock rb26dett after changing a few things like the turbos and the boost level etc?
I'm looking at using an rb20det redtop NICS engine in my mr30 skyline and we expect about an approximate 150rwhp straight up out of that and the engine is costing me about $500 total with other gear like the radiator, exhaust down to the catback minus the g/b.
But I guess knowing someone who knows their shit is also a great help when doing this stuff up close. That and sneaking in on cheap deals, -though i should probably be going with a different RB, lol.
Normally Aspirated was our plan. Non Turbo!
I am going to have more than 300rwhp from a turbo L series, which is the point I was making.
And at the end of the day, about 300rwhp is aqll you can use, can't get much more to the ground without masses of wheel spin all the time.
Ahh yep, sorry, it was me who made the mistake here.
What was that you said about whiteline swaybars? I picked some up recently for $165 for the pair, but the holes on it are a bit big for the swaybar link bolts I've got. The holes in the standard r30 swaybars are about 10mm where as these ones are 15mm for the front and 13mm for the back.
Although the other day my friend and I collected some swaybar links from an R31 and there was a gap there also.
Hate to do the distracting here but this is a little quiery I've got that I'm sorta procraztinating over.
the bushes are supposed to go into the holes in the sway bar as well... if the raised step on your bushes are gone, get some new ones. urethane bushes will also effectively stiffen the bar up a bit too.
What diameter did you get for $165/pair? Front ??? & Rear ???
I'm not a huge fan of Whiteline, but they will make anything you ask for, but you are on your own if something breaks due to your poor design order. They warranty the bar, but not the end result.
And I bought NEW! not second hand.
Cheers, D
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
