I did a search of my own posts the other day knowing that I had posted something particular a few days ago and noticed a few of the posts I remembered making were missing from the list.
Well I didn't think too much about it and continued on my merry way.
Now I just went to a thread which I posted in - and saw the post, yes I did click the post button - this afternoon to see what other posts had been made and my post was not there.
What's going on?
https://www.sau.com.au/forums/topic/142646-disappearing-posts-again/
I was pretty sure I made a post the other day, and when I went back to find it, it wasn't in the thread I posted it in (or thought I posted it in)
Then I went through the list of my previous posts, and it still wasn't there, so either I didn't actually post it, or the forum really is eating stuff.
I just had a sift through the rubbish, and the only recent post i can find belonging to hanyou which has been removed appears to be a whore post which was removed from a for sale thread on the 19th of October.
are you sure it's not related to this issue you posted about a few days ago?
http://www.skylinesaustralia.com/forums/in...howtopic=141552
Ok, if you post something only to find its gone missing, please link me to the thread and give me as much info as possible (eg when you posted, if it had a title etc). I'll see whats going on.
Adam, tell me if all your posts are there.
The thread i "thought" i posted in was this one:
http://www.skylinesaustralia.com/forums/in...howtopic=142133
I think it was on the 7th, Eug's was the only reply in there at the time, I think I moved the thread from the general discussion area and then posted in it, or posted in it and then moved it.... either way, I was still sure I posted in it... sure enough that when I came back and my reply wasn't there I got confused, i searched my previous posts for it, went through the bin looking for it, and couldn't find it, so i just decided that i mustn't have posted in there after all.
  • 3 weeks later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
