hey there guys, another noob question by myself.. =)
the rear view mirror tends to vibrate once it reaches speed of 60-70 (i think about this speed) and above and it's pretty irritating, cuz..hehe at higher speeds, i can't check for cop cars behind me. and all the cars behind are at a blur..i have to hold the rear view mirror to make out the lights on the car..
anyway to eliminate this shake?
another problem (if it's called a problem) is that the steering wheel tends to vibrate/shake once it gets to speeds about 80-90, is there anyway to stop this? or is this a problem with my steering.. in my previous car a toyota echo, the steering wheel don't vibrate (silghtly) till i get to 130-140 (altho the whole car was kinda wobbly)... i don't understand why a skyline's steering wheel's feel isn't as good as a toyota echo.. anyway to fix this?
i don't mind paying a little money to get rid of these problem.
cheers
the mirror, get a chunk of rubber and wedge it between the glass and the mirrors arm. worked for me and cost nothing. the steering wheel i also have the same issues. try a wheel alignment and balance. get the steerin system checked over. things like rubbers etc on the steering arms and that
Sounds like you need a wheel balance, if it still does it at higher speeds get an on car balance, fixed my problem, oh yeah your mirror will probably stop shaking too.
hi there the wheel balance is a wheel alignment? what is a car balance?
cheers
A wheel balance is where they take the wheel and spin it, a sensor on the machine that spins it detects any imbalance in the gyroscopic effect and recommends a weigth and a position for it.
A wheel alignment is done on a bed with 4 pads and the alignment of each wheel is checked in relation to each other, so that it drives straight and corners properly without undue tyre wear.
A vibration could be the result of an unbalanced wheel or 2 wheels fighting for direction.
*nods* alrite thanks =)
i think i just had a wheel balance, I just got new rims/tyres put on my car about 5 days back.. so the balance of the car should be fine.. I think i'll take it for a wheel alignment tomorrow
thanks =)
I had much the same problem, I had 2 wheel alignments and numerous balances but it wasn't untill I had an on car balance that it went away.
Usually the weights used are in the 10-20 gramm range, I needed 58 on one and 62 an the other, whch is unusual so he said.
A wheel alignment generally is not a cure for wheel vibration.
If you had new wheel / tyre combo fitted, are the wheels "hub-centric" (they need to be)? The other possibilities are things like worn steering bushes, worn steering rack, loose wheel bearings.
The mob that sold you the wheels should be able to diagnose and fix the vibration.
Its funny how many people balance up wheels (especially aftermarket rims with stick on weights) and just get it close. In my experience with stick on weights it is quite time consuming to get it perfect. Like Blind Elk said go back to them for a fix..especially if it has only happened since getting the new wheels.
Hi there, i tried wheel alignment/balance alreadey and the rearview mirror is still wobbly.. can you tell me where to get the rubber from? and wat type of rubber is it.. is it a small piece/ medium piece etc?
cheers
go to a bike shop and ask for an old tube. they should give it to you for free. if they don't call them scummy bastards and walk out and find another bike shop.
then just cut a bit of the tube off and wedge it in.
Dude I would be more concerned about why you have a vibration, if its not the tyres or alignment it could be your drivetrain, the tailshaft could be out of balance, vibrations are a sign of something wrong if you dont sort it, it could/will cause even more problems.
LOL i aggree.
Still if its just a loose rearview mirror then it'll move with an kind of vibration..
hi there i got my wheels changed and noticed a vibration at high speed..... took it back to be balanced again...... they didnt balance it properly the first time..... get another balnce done!
I'll give this another shot.. i'll go back to another place to get my wheel balanced and see if they can find any fault..
thanks mate =)
sorry to keep repeating my question =)
just need to know where to wedge it in... at the clip thing which is at the center portion, bottom of the mirror?
thanks
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
