John, I'm amazed at your absolutely care-free attitude to this event. If someone followed me, I would pull over only in a very public place if at all. And one day you will chase the wrong dude and he will get out of the car and A. Throttle you. B. Throttle you and take your car. Or C. He will be your favourite off-duty cop and he will throttle you and throw you in jail.
Your actions only perpetuate the road-rage phenomena. Yes, there are fools on the road, but two wrongs don't make a right.
Be the bigger man and let it slide.
Thats it hey. Its the 'unknown' factor. You dont know what is in their car, what they are on, why they cut you off, who they are etc. He could have just robbed a bank, killed the guard and not give a rats if your the next victim.
Seriously dude, say on your average 30min trip, you could let 5 cars in, the MAXIUM that is going to add to your trip is 1min if its heavy traffic.
But in regards to the keying thing, I hope the barstards get real bad hurt, by say an angry bull shark or something. Keying reallly gets on my nerves, if they push hard enough its got to be the hardest thing to fix up properly.
thanks everyone - i really appreciate the sympathy
That scratch looks very deep, buffing it might reduce it a bit however you may need to get it resprayed
yeah it is deep and yeah think your right... wonder if it would be cheaper to replace the bonnet.. probably not hey. i might go and look in the "good places to take your car" sticky thread to see if there are any recommended shops who do respraying
Go see Carey at showdown customs Everton hills, he does a good job at a good price.
0_o that sucks balls man.. I dunno what it is about skylines but it always seams to attract wanker's attention.... Is it the fact that we could beat them in a race ? or maybe the fact we had enough money to buy a car that isnt falling appart around us ? or maybe the fact that we were smart enough wid our money to actuelly save up for something nice 0_o
This will never be answered but the fact is there will always be retards on our roads and streets and theres nothing we can do... Thats why god created carmagedon... ^^
Ben u play too much games. i have no idea what 'carmagedon' is? can u speak english?lol
It's a game where you score points for running people over :)
I get the same shit in our BMW. Everyone cuts you off, tries to race, etc... These people have a very small penis :)
judging by your reaction and the fact this shit actually happened to your car, you dont happen to live in woodridge or anything do you? =P
wats with ppl baging out this area for F$%K sake, iv lived in woodridge for the past 12 yrs
an not one thing has happend, my car gets left out side, hardly ever under cover, windows down
sometimes. ECT........ woodrige is no different to any other area.
Word. :nyaanyaa:
Some people just hold onto the past like it was only yesterday. You know what is funny, Southport / Surfers paradise have the highest rate of automobile break ins and theft in Qld, yet you rarely hear anybody say anything bad about those suburbs.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
