You can also get a cams lic by applying at Pitstop Bookshop , King st , Perth
Gazza
That's a nice pic of a cool GTR
You can get the forms by downloading them from www.cams.com.au
If you join the wascc you will get free entry to most events (V8's included), access to practice days, a quarterly mag & other good stuff.
  • 1 month later...
i'm a member of both AFARCC and WASCC...
Both are CAMS affiliated, so you can get your CAMS license through them...
Both run wanneroo track days, but the AFARCC ones cost about $100 each and happen twice a year, while the WASCC ones happen about 4 times a month and cost about 40 bucks a day (it helps that the WASCC own the track :D )
WASCC membership also gets you into all the race meetings, including the V8 Supercars and the SuperTrucks and all WASCC run drift events...
AFARCC membership gets you cheap entry into our AHG skidpan days, our Wanneroo track days and our Collie days, plus invites to our cruises and social events (like the pub crawls we run once or twice a year)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
