the following items are for sale with more to be added
- stock r33 air box with filter and all bolts $30 ...
- vacuum guage (autoguage) smoked $10 NEW NEVER USED only opened to check if all parts inside!!
- 4stud space saver wheel $30
- theres 2 covers deflectors which go under the r33 to keep rocks n shit away from ur engine $15 each
- engine oil cap stock s2 one $5
- ***GENUINE series 2 rear spoiler (WHITE) all fittings bolts etc and mounting points in tact in perfect condition 150 firm!***
pics all here now if any pics are missing let me know
- R33 series 1 bonnet white (painted properly inside and out as i had my engine bay repainted in the nissan white coz they do a shit job from factory) **make me an offer***
- 18 x 8" 4stud 114.3 ( Davinci blade chrome) rims bought one month ago with brand new tyres no scratches no marks etc $1400ono
PM ME if you have any questions ta or call me 0406 535 180
Edited by DaGr81
https://www.sau.com.au/forums/topic/143193-r33-s2-parts/
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
