  • Replies 52
Posted Images
excellent turn out guys! We lost a few in those hills. At one point i could see darkness infront and behind me, and no mobile reception with petrol flashing Empty
haha, s'all good
Never thought vans were RWD haha
Wonder if the cops got him
For people who missed out, we were talking in the meet point and a white van pulled up and started doing a burnout. It was like a VW van? i think.
Shortly after a cop arrived and asked us about the van?
Friendly cop he was
Next friday!
that was a nice little cruise, bad communication though. I mis-directed a whole bunch of ppl because I got told that everyone was going onto the princess hwy. After I found out we were going into the mountains, it was far too late! Sorry about that :rofl:
Took a while for that cop to rock up... don't know how he knew about that van! Funny as hell though.
Alexcim : we met at springvale???
Andru: Nice to meet you Andru, what happened to you??
Edited by SuAvE-1
Hey all!!
Was a good night, a little more organisation is required in future :rofl: . If any of you guys are interested in another hills 'cruise', post up some interest and I will see what I can come up with. Hope you all had fun!!
Cheers, James (White R32 GTR) GTR-26
next event everyone bring cb radio's. As Andrew and I were the only ones. No mobile reception up in hills either so couldnt get in contact with anyone falling behind.
There was only one awd car (r32 gtr) and he was leading us through the hills haha
I reckon around 15 cars attended this meet/cruise?
Next cruise, stay away from cranbourn(sp?) maccas. Full of 15yr old kids with weird attitudes lol
Haha that was funny!
15yo's Call us names, then asks you for a lift Hahahaha
good cruise, much more orgasnised than others i have been on before (holden and ford onea are shocking!)
got lost a few times but we eventually found our way around!
Edited by BOGAN
Cranbourne!! damn... we really got split up!
GTR 26: Awesome run through the hills, definetly down for some of that again
I estimated about 20-25 cars at the meet, for some reason seemed like more, good fun none the less
EDIT: Definetly down for some more pictures helio!
Edited by SuAvE-1
We got back onto princess highway, and we (mostly just I) was hungry and only opened place was mcdonalds at cranbourne haha.
After each cruise we should meet up at one point. Was a mess on what to do next as everyone just left as we got onto princess highway
Yea a meet point at the end to say good bye,iz a good idea. I agree this was much better than the Ford or Holden one's. The one that I went on people were hitting other cars, draging at the lights, the police had a ball... no organisation. I think that if we do something like this on a regular basis then it will only get better.
Yeah i was suprised you alowed my holden to cruise with you with no dramas!, i know if i took my holden to a ford cruise (ive seen what happens when a holden comes to or just passes a ford cruise), or my ford to a holden cruise, theyd bag the ******* out of me and chase me out lol
i'll deffinetly cruise with you all again!
Edited by BOGAN
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
