Hey,
If you don't mind me asking. If thats your car in pic, where u get the clear indicators
yes thats our car...d-speed in Japan is where we got the clear indicators from
https://www.sau.com.au/forums/topic/143412-gtr-bits/#findComment-2675250
wouldn't happen to have the top linkages from the throttles? goes from the plenum to the throttle arms? How much?
Like this:
http://i58.photobucket.com/albums/g254/Loa...ign/linkage.jpg
linkages...$100
https://www.sau.com.au/forums/topic/143412-gtr-bits/#findComment-2675490
Are you saying that as in buy the throttles adn you'll get the linkage or $100 for just the top linkage?
you asked for a price on the throttle linkage only....i gave you one
https://www.sau.com.au/forums/topic/143412-gtr-bits/#findComment-2676176
  • 3 months later...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
