Hiyas
I urgently need a couple of pieces of interior for my 32 gtr...
firstly the under dash fuse box surround and panel, and secondly the centre console middle brace (pictures attached below of the pieces I removed).
Dont like the screw holes. wanna replace it this week ;P
Thanks
-D
http://cgi.ebay.com.au/Nissan-R32-Skyline-...Z1QQcmdZViewIte
thx rocky
while ive placed a bid on that just in case, im more after something I can outright buy :P cheers for the link tho dude
-D
no worries  :) Although remember, if you win the auction you have to buy it.
But its worth waiting at that price... most wrecking places will charge you something like $300 for it.
Edited by Rocky88
after a few bits for the interior....
-a manual center console (as my gearbox died im doing a manual conversion)
-the center air vents for an r32 (not broken ones :D )
-inside door handles for an r32 (mine are faded would like new ones)
-r32 GTR rear seats (i've got GTR front seats and would like the rear to match)
-r32 pass. front seat floor mat for a 2 door (the ones that came from factory that say SKYLINE on them, i've got all the others but that one for some reason :s )
-also, still looking for some new brake rotors. need the fronts more then any of the others but may buy all 4 for the right price!
thanks
kye
Hrm mine are faded too and I'm gonna get some spray paint next week and do them (in black) if you wanna take yr old ones out I'll do them at the same time
-D
yeah i can get them shipped over here. And there are 34 stuff to. ive come to a total of around 1k delivered for most of my interior in carbon hehe
I see a couple of pieces that I'm after Luke, what do I gotta do to get you to import them for me mate?
-D
ah so these are what your brother was talking about.
can you get craig to msg me when he plans on getting a few things over? ill most likely take manual center consol surrond thingo and maybe the door handle bits too.
pay less on shipping with more :D
WANTED
Late model R32 GTR V-Spec......must be reasonably good condition.......must be an Aussie delivered model
PM with pics, details & price please
I dont think the V-spec's were aus delivered. Only aus delivered GTR's were the 1991 batch of 100... rest are grey imports (can anyone confirm?)
-D
would be close to it Ben, heres the specs:
To celebrate the success of the GT-R in both Group N and Group A racing, Nissan introduced the Skyline GT-R V-Spec ("Victory Specification") car on February 3, 1993. The V-Spec added Brembo brakes and a retuned ATTESA E-TS system to the Nismo and N1 packages, as well as 17" BBS wheels with 235/45/17 tires. The V-Spec has a list price of ¥ 5.260 million.
Finally on February 14, 1994 the Skyline GT-R V-Spec II was released, with the only change being wider 245/45/17 tires. Total production of the V-Spec I and II was 1,453 and 1,303 units respectively.
I want one of those please
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
