Does anyone know where I can buy/order some different springs for my JIC's here in adelaide or on the web. I bought them last year but the 8kg front's aren't as responsive as I would like. I want to get 10kg.
I dont really want to go to a wrecker and them saying "Yeah, we can order some but they'll only come in or next container" Which will take forever!
Any ideas?
what are you buying for kye? u get a new ride?
for my new ride i need a stock r32 gtr steering wheel and a stock rb26 cam gear cover have clear greedy cover if someone wants to swap!
isold the 32 and i bought a drift car :P its to keep me out of trouble till i get my evo. its got long champs 16x7-0 and 16x8+2. once i saw them i was sold haha
im guessing by the bits your looking for youve got yourself a gtr :P ill have to come have a looky
also
wtb- bride fixed back seat (any will do)
- nardi steering wheel
-half cage for a non sunroof s13 sil
cheers
Edited by Import S13
Items:
RB25DE Half Cut/RB20DE Half cut
Extra Info:
I am after a RB25DE half cut for a engine conversion project
or a RB20DE.. Also if it is close to brisbane/Sunshine Coast
Contact Details:
PM or email: [email protected]
Price and price conditions:
Open to prices atm..
Wanted: Cheap daily driver that's reliable. Maybe something like a VN commodore or something cheap and manual. Couple of mates have scored some decent cars for around $500 so if I could do the same it would be great! Send me a PM if you got something to offer.
lol you wouldn't even get a cheap fibreglass knock-off for $300-$400 Keitz - $950 is around the going rate.
theres 2 for sale in the classifieds section of sau one 550 delivered with clear nismo indicators and the other one 600 bucks but all good my friend got one i borrowing his.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
