Looking for a cheap cd/mp3 player for my daily hunk. PM me if you got something on offer.
i have a pioneer cd deck that was in my 32 before i upgraded..
flip down with mp3, the contacts were playing up abit (didnt display 100% unless you pushed the screen) but worked FINE.
$50?
$50?
PM sent... well sending :(
Ok I'm looking to but a set or even one Tie Rod End to suit Series 1 Stagea due to noone knowing a non genuine replacement part number.
If you've got one to sell in good nick I'm keen to buy before the cruise on sunday due to major free play.
No Idea what they're worth, just let me know if you've got one to sell.
WTB r34 gtr rims... prefer with tyers but either way... pm or msg
0400099986 cheers adam
when u find a set that cheap plz let me know, been looking for ages and haven't found a set under $2k for ages if ever!
yeah same as me! wanted to buy R34 GTR RIMS FOR
$1700!!!
$1700!!!$1700!!!$1700!!!
$1700!!!$1700!!!$1700!!!$1700!!!$1700!!!
$1700!!!$1700!!!$1700!!!$1700!!!$1700!!!$1700!!!
http://www.skylinesaustralia.com/forums/Ni...18-t257529.html
that would be like 2200 posted
still a good deal imho. if i had a spare 2k i'd def get 34 gtr rims (unless any crazy 34 gtr owner wants my 32 gtr rims as a swap? :blush:)
those look in excellent condition too
*sigh*
-D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
