Being a GT-R you will need same width and tyre width all round,
I'm 90% sure the same rolling diameter cannot be acheived even if you run the same width tires etc.
Plus its bad for understeer which GTR's already have trouble with.
^^ wanna do mine? other wise its going to precision diff, to cost me an arm and a leg :cool:
dude its easy as. will take you a while tho depending on how you are with your knowledge and tools.
trust me you should be able to do it yourself. and for sweet fa. ill be at u pull it tomorrow getting my parts and then to combine and mini spool. give me a yell if you get stuck.
Hey guys, after a stock r33 gtst fly wheel
condition: any
Prcie: im easy, what they worth?
pm me
cheers ash
Cearing out the garage again in time for the new project
r32 front heater core, all air con piping and air con pump with bracket. basically everything u need.. $140 ONO
rb20 alternator. $40
rb20 crossover pipe with bov. $80
standard rb25 engine mounts with no bushes. $25
rb20 rubber intake pipe. $25
rb20 turbo. was leaking a bit of oil but minimum shaft play $60
rb20 front fan, not sure wat its called, runs off the engine. i think its called clutch fan? with the plastic cover around it but covers got crack up top. $40
rb25 standard clutch $25 or if u want a week ill have a flywheel aswell and u can have both for $90
rb20 exhaust manifold. looks ok condition. $25bux
some random blue/black drift brand steering wheel. good condition $15
txt or ring me on 0428851616 or pm me
cheers
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
