hi all i am after a drivers side window motor and whatever goes along with it, for a 1994 r33 coupe (drivers side), went to wreckers in lonsdale and they want the arm and leg for it pm me please if anyone has got one.
cheers... michael
I've got a whole driver side door with all the parts I'm willing to strip
throw me an offer on the parts you need.
I'm in need of some stock front shocks for an R33
don't care if they are fkd. Need to move my shell asap
Hey guys,
I am after a set of R33 GT-R wheels. Let me know what you have got.
Tyres or no tyres, powder coated different colours is okay too. Just PM me what you've got.
Need an 'inbetween' set of wheels untill I buy a pair of works :) .
PM or [email protected] - Thanks.
ive got sum, but not sure ill get rid of them unless im offered a decent price, tyres are 80-90% tread but rims have a fair bit of gutter rash which were the way i bought them from JMS
i think im near u aswell at Alberton
I have found a pretty mint set of them for $1,000 no gutter rash at all with good tires so I don't know how much you think they are worth? And yeah Alberton is just around the corner from me mate
QUOTE (BIT SUS @ 19 Dec 2009, 12:29 PM)
urgently needed:
1 x R33 Air condensor mine is a series 1, not sure if they are different across the years.
ta
anyone got one?
i got one but its off a stagea! it didn't fit my s2 r33 so it might fit s1? if you still need one?
Edited by sean_ps13
hey mate, got a new pair of frp vented +25-30mm guards for 32. pre drilled holes, perfect fittment. 335 pair
$$320 pre frilled, top quality guaranteed, Vented guards+25mm new checked wraped and ready to go
and questions please call 04215 03215 thanks
Are the Jun front lips plastic of FG, also any pics?
r32 GTR JUN front lip $220 fiberglass not carbon!!! 1 available
and r32 GTR ABFLUG/w undertray $380 in carbon only 1 available
this is all i have nothing else thankyou call 0421503215
also have topsecret rear spats and jun rear spats. sms your email for more pics or call for info
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
