Hey im in need of r34 GTR bov's and piping or any bov's and piping for a rb26dett. It has to have the recirculation piping from the bov's back into the engine as i need it to be full plumb back. need it to pass the pits. please pm me. even if someone has some which i can borrow it would be great.
Cheers
David
Heymate, I got stock BOVs, and some piping from my 33 GTR, you are welcome to borrow.
just send me a PM.
Nigel.
will let ou kow in a day if i got one or not as someone else is spose to be grabbing mine, if not i will pm you
$75 for ya if it doesnt get taken by the other guy
thats a bargain, these are hard x members to source, i have seen them sell for over $200
WTB:
Z32 afm with plug
555cc injectors
HIGH flow rb25det turbo
all for s2 rb25det.
adrian, i'll keep ya posted on a z32. found one cheap cheap second hand in good nick (comes with plug and a bit of loom too). getting one for myself too
WTB
2x pairs 255/40/17
doesnt matter condition, more shagged the better. as long as they will hold air im not fussed. Cheaper the better too. Need them as a "construction" tyre, rather than have a good set of R888s getting raped by gravel, angle grinder sparks and welding slag
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
