wanted:
1metre length of steel tube
14mm outside diameter with 1mm wall thickness (ie 12mm inside diameter)
cant find anything. can anyone help point me in the correct direction.... tried all metal suppliers down south with no luck
wanted:
Bahnerts Steel Supplies on OG Road might be able to sort you out, bit far north for you maybe but they have a decent range.
Otherwise Smart Aluminium if you're happy to have an aluminium tune
-D
-D
thanks.
need to sleeve some bolts (brake upgrade), will head out to OG rd and look/see
wanted:
You trying to sleeve R33 bolts/calipers onto Stagea/R34 hubs? :thumbsup:
Items:
550CC+ Injectors. Must be Direct replacement for R33 Series 2 RB25DET
Extra Info:
Side Fed
High impedance
Must be direct drop in
Support 300rwkw
Connectors and collars
Contact Details:
Contact via PM
Price and price conditions:
Budgets around $500
WTB 34 GTT bits
1 x driver side pillar (black), i think its the A pillar (mine has holes in it from stupid people doing stupid mods)
Valve covers for rb25det (polished preferred or stock)
2 x lef and right side console covers (ones that go each side of the radio) mine are scratch to hell.
intercooler core. Anyone got one laying around?
have a hybrid fmic sittin here. has a dent and not sure if its any good but welcome to have a suss and revel in ya old 31 ;). still dont run tho :blink:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
