what were you getting and how much
*cough* convert to top feed *cough*
600cc high flows, all professionally done with flow charts per injector etc... $400 delivered from US
i dont mind spending a bit more but i need them like yesterday =/
Anyone with an RB motor lying around (almost any RB motor) that I can gets bits off ... like nuts and bolts?
I'm rebuilding an RB26 and can put it back together due to nuts and washers and bolts missing here and there. such things like:
ex manifold washers and nuts (x2), turbo to manifold nuts (x2), inlet manifold washers and nuts (x3) etc
PM me and let me know what you got. Would like to finish off some things on this engine monday.
:thumbsup:
:thumbsup:
I would highly recommend using new washers and nuts on anything that will have to sustain high heat due to heat distortion/deterioration. Even minor things on an engine you're better off buying a bunch of new nuts/bolts/washers anyways.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
