600cc high flows, all professionally done with flow charts per injector etc... $400 delivered from US
i dont mind spending a bit more but i need them like yesterday =/
I have nismo 550cc injectors that were on a series 1.
PM me if interested.
WTB:
R33 boot latch off the body
R33 boot interior clips
DDR2 memory sticks
[/qu
Just Jap for the boot lock mate give em a call it takes a day to send. $200 I got mine for now I just have to get it into my 32 boot without butchering anything...
I want the latch, not the lock. and Im not paying $200 for a latch...
  • Like 1
  • Nope 1
Hey guys, need a gear shift stick as the original owner deceded to cut the thread off of it.
Pm me a price if you have one laying around.
Japanese Import Spares have brand new ones, they're around $100.
