Hey guys,
If Anyone has these parts in good condition I am looking to buy asap!
1x drivers side door electric window control plastic surrounds... As I snapped it :(
1x gear stick plastic surround with the cigarett door thingy.
1x plastic A frame drivers side as mine has some holes in it due to mounting boost gauge holders...
Please PM me with a price if you can help :) cheers
WTB: still after r32 gtr bonnet and grill....
ive got a gtr bonnet with a small golfball sized dent on the front left wine red. and could possibly let go of grill if it was all at the right price
After the following parts to suit r32 gtst
r32 gtst (or GTR) Drivers door - prefer black, in good nick
r32 diff - std one required for regency. I can shim it, so worn ones are ok
r32 gtst - tail shaft. One that runs from the gearbox to the diff, not the sub axles.
Have exams on this week coming, so can pickup anytime after friday.
Is this turbo back to cat?
this one is from turbo to front pipe only, full stainless very good condition.
i've just never found the time to fit it.
this one is the same, but it's for sale on ebay for $145
